06-15-2023, 11:33 AM | #1 |
Not great. Not terrible
7445
Rep 2,700
Jackie Ding and his G87 M2 on the track again.
Featured on BIMMERPOST.com I liked seeing his drive mode settings and how they changed over the sessions as he works to find the best mix of settings.
Current: 2024 BMW X3 M40i.
15
Tag18149.00 bmwimsafan23.50 Tch-Nrd124.50 ///M TOWN16524.50 GuyOh1067.00 Kevin_The_Clean13269.50 M3 boi3211.00 2srsman68.00 babym_gen134.50 chrisjguzman95.50 ilia381.00 SimsimmaM3172.00 ronin13013999.00 Sherlock997218.50 |
06-15-2023, 12:35 PM | #2 |
Rep 105
Interesting to see him running the engine in "Efficient" mode. Most likely to smooth out the throttle response due to cold track temps and lack of grip?
Also, do only the cars with the carbon trim option get carbon paddles? I thought all auto M2s get the carbon paddles. |
06-15-2023, 03:19 PM | #3 |
Rep 63
It would be interesting to see what mods the other cars are running.
Because he is relatively competitive but still has a lot of things he can modify. Suspension, tires, aero, more weight loss (sound foam, airbags, rear seats, ...), engine and zf8 tunes, ... |
reward72321.00 |
06-15-2023, 05:37 PM | #5 |
Rep 1,546
06-15-2023, 06:10 PM | #6 | |
Rep 2,700
Your better up picking Sport or Sport+, getting used to it and mastering it.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
06-15-2023, 07:16 PM | #7 | |
7406
Rep 10,215
06-15-2023, 08:01 PM | #8 | |
16525
Rep 8,423
Finally worthwhile front page news I seriously love the passion you have
06-16-2023, 07:24 AM | #9 |
Rep 219
again w the understeer. Man that is so annoying. The other M2 had the same thing, why can't they fix this. It's very annoying, M3, seems to have this better controlled.
06-16-2023, 07:56 AM | #10 |
Rep 105
Started the day in sport, but ran the rest of it in efficient.
AlpineBoost3927.50 |
06-16-2023, 09:37 AM | #11 |
Riding the knock sensor
2371
Rep 1,591
Drives: 21 X5MC | 23 M4CSL
Better throttle range/control.
06-16-2023, 01:49 PM | #13 |
Rep 22
Thanks guys! I'll keep updating my original build thread too. It's been a while.
The understeer, turned out to be a really isolated issue. For whatever reason, the Cup 2 Star spec made the car incredibly understeer-y. As soon as I threw the OEM PS4S* back on the car the following weekend, the M2 suddenly had way less understeer and actually turned a faster lap time than this video. It was a startling revelation and I'm currently under the opinion that the Cup2* is a waste of money and time for us M2 guys. Haha. And yea, having tested all the modes, Efficient on engine mode gave us the best throttle modulation needed. Sport is already fairly aggressive and it feels like Sport+ was even worse. |
12
AlpineBoost3927.50 JustinHEMI7445.00 GuyOh1067.00 bmwimsafan23.50 M2siast5876.00 PLF693766.00 werdn656.00 M3 boi3211.00 DailyDownshift453.00 SimsimmaM3172.00 MG20i120.00 Searay55555376.00 |
06-16-2023, 01:50 PM | #14 | |
Rep 63
If you want to shift the balance toward more oversteer, it's up to you to do it knowing the risks. You can increase front negative camber, make the rear stiffer, bigger front tires, more rake, ... |
JustinHEMI7445.00 werdn656.00 |
06-16-2023, 02:08 PM | #15 | |
Rep 67
babym_gen134.50 |
06-16-2023, 05:41 PM | #16 | |
Rep 168
Drives: G80 M3 GTP 6MT
PLF693766.00 |
06-16-2023, 06:39 PM | #17 |
Lotus Exige ClubRacer
26
Rep 157
Drives: MY15 Lotus Exige CR
Cup 2s have a narrow operating pressure window on the track. They work well even in cold ambient after you get some heat into them. What were your hot tyre pressures as your came off the track at the end of the session?
Lotus Exige CR …. Upgraded Stereo, Cruise Control, Rear Parking Sensors, Full carpet kit with sound insulation ..... its a daily driver
Charge Cooled TVS 1900, 3" bi-modal Exhaust, Moroso Sump, LSD, 60l Alloy Tank, Upgraded 2 Piece Rotors, 46mm Nitrons, Harness Bar and Forged Track Wheels with Yokohama AO50 R Specs for play time |
06-16-2023, 07:08 PM | #18 | |
Rep 63
Assuming they are somewhat precise, they were way too low (100, 120, 150 at most). Ideal temperature I think is around 194F. Maybe they were overinflated. (edit: so from the dashboard, it doesn't seem to be the case, if anything they are underinflated) Fun fact, in asseto corsa, I always struggled to get heat in semislicks in non-areo street legal cars. I had to drop the tire pressure a lot. |
JustinHEMI7445.00 Sherlock997218.50 |
