Bimmerpost
4 Series
Technical Topics Cosmetic Maintenance: Wash, Wax, Detailing, Repairs My current list of favorite car care products if helpful
      12-12-2022, 09:33 PM   #1
MichaelB1969
Drives: 2023 G80 Base SSG/Fiona
Hi all, new member here with a car on order. Over the years I have gone through many, many different car care products.
Here's a list I created for someone with the products I currently rely on. Figured I'd paste it in if helpful! That said, always open to trying something new if anyone has strong recommendations!
Wax equivalent (VOC-free and REACH compliant)
https://www.amazon.com/IGL-Coatings-.../dp/B085SYSNGD
Polish
https://www.amazon.com/Pinnacle-Blac.../dp/B00GHVYHBE
Car wash
https://www.amazon.com/Pinnacle-Blac.../dp/B015Y526RA
Clay bar equivalent
https://www.amazon.com/Nanoskin-AS-0.../dp/B00DOS0LH2
Lubricant for use with the clay bar equivalent
https://www.amazon.com/Nanoskin-NA-G.../dp/B00DOS0KC8
General-purpose cleaner
https://www.amazon.com/dp/B000VBA8FK
Wheel cleaner
https://www.amazon.com/Sonax-230400-.../dp/B07Y48R3YQ
Microfiber towels
https://www.amazon.com/Chemical-Guys...dp/B00A8MZ7IA/
Microfiber applicators
https://www.amazon.com/Chemical-Guys.../dp/B00BJCN7Z8
Wash mitt
https://www.amazon.com/Chemical-Guys.../dp/B086HKHWZ4
Bucket with grit guard
https://www.amazon.com/Adams-Grit-Gu.../dp/B0828BFG39
Leather cleaner/conditioner
https://www.amazon.com/Meguiars-G201.../dp/B08B43M5F8
Vinyl protectant
https://www.amazon.com/303-30382-Pro.../dp/B0185PU38A
Glass cleaner
https://www.amazon.com/Stoner-Invisi.../dp/B000M3V95U
Brushes for air vents, between panels, etc.
https://www.amazon.com/HMPLL-Detaili.../dp/B08LN6CZKD
Wheel brush (gets into the rim area behind the spokes)
https://www.amazon.com/SPEED-MASTER-.../dp/B00E9E76F0
Wheel brush with long handle (for outer rim surfaces)
https://www.amazon.com/Mothers-15580.../dp/B001GJ3E2K
Black trim treatment
https://www.amazon.com/Meguiars-Ulti.../dp/B0055PD1H4
By the way, I used to use Meguiar's All-Purpose Cleaner instead of Simple Green, that is, until I read the label. Let me tell you, it is absolutely frightening! Here is what the Meguiar's label says:
IF INHALED: Remove person to fresh air and keep comfortable for breathing.
IF ON SKIN (or hair): Take off immediately all contaminated clothing. Rinse skin with water/shower.
IF IN EYES: Rinse cautiously with water for several minutes. Remove contact lenses, if present and easy to do.
Continue rinsing.
Immediately call a POISON CENTER or doctor/physician.
Wash contaminated clothing before reuse.
IF SWALLOWED: Rinse mouth. Do NOT induce vomiting.
Call a POISON CENTER or doctor/physician if you feel unwell.
Absorb spillage to prevent material damage.
For comparison, here is what the Simple Green label shows:
Inhalation: Not expected to cause respiratory irritation. If adverse effect occurs, move to fresh air.
Skin Contact: Not expected to cause skin irritation. If adverse effect occurs, rinse skin with water.
Eye Contact: Not expected to cause eye irritation. If adverse effect occurs, flush eyes with water.
Ingestion: May cause upset stomach. Drink plenty of water to dilute.
      12-12-2022, 09:49 PM   #2
peelerec
peelerec's Avatar
988
Drives: 2022 M340i Mineral Grey
2022 BMW M340i  [0.00]
I would suggest a PH neutral car shampoo such as Koch Chemie GSF, or Carpro Reset.
Also, there are many more microfiber towels much better than Chemical guys including but not limited too The Rag Company and Luxury Microfiber.
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR
acudaf82173.00
      12-12-2022, 10:13 PM   #3
MichaelB1969
Thanks for the tips! Would you recommend those shampoos for manual shampooing too, or mainly for using with a foamer?
Will give one of those other microfibers a try!
      12-12-2022, 10:17 PM   #4
peelerec
peelerec's Avatar
988
Yes, both of those are perfectly suitable for manual hand washing without foam. My personal favorite is Koch Chemie GSF. Really thick lather, even without foam gun.
g20
