07-14-2022, 12:15 PM | #1 |
Rep 149
Brand New m5 comp already in limp mode
Hey guy wanted some chime back on this. Car just went to dealer will find out but has anyone experienced this ? The car went into limp mode last night shaking a bit stuttering on rpm's let it sit overnight to the same thing in the morning got these two codes don't know what's going on. Any help ?? Car is brand new it's pissing me off it's already at the dealer
Current: ?22 F90 M5 Comp Individual Imola Red
2018 c63s coupe sold |
07-14-2022, 03:26 PM | #2 |
Rep 5,235
DTML is catch-all in some ways so it can be a number of different things.
I've had this for several things including coil packs, plugs and intercoolers.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
07-14-2022, 06:11 PM | #3 | |
Rep 1,799
07-14-2022, 07:16 PM | #4 |
Rep 152
Drives: '22 Dark Graphite M5C
You have twice the miles mine has and mine's getting a new engine. I didn't even make it to the break-in service yet.
I feel for you though. I've been without mine for 2.5 weeks and they haven't even started putting it back together yet because they don't have all the parts. |
07-14-2022, 07:17 PM | #5 | ||
Rep 149
What did they say happened to yours ?
07-14-2022, 07:23 PM | #6 |
Rep 152
They literally have no idea because there were no fault codes. BMW is making them send the engine, turbos, oil cooler...all of it, back to them for analysis.
It's super frustrating. I purposefully didn't drive it for the week leading up to the PPF and ceramic coating. After being at the tint shop for 4 days, I was able to drive it for a whole 10 days before the engine just decided to quit. |
07-14-2022, 07:30 PM | #7 | |
Rep 149
07-14-2022, 07:39 PM | #8 |
Rep 152
07-17-2022, 09:17 AM | #9 |
Rep 155
Had same issue with my used '21 M5C. Drove home from dealership, everything was fine. Wanted to go for a night drive and BAM, Drivetrain Malfunction. I was pissed off to say the least.
Ended up being a bad fuel injector causing misfires. Good luck |
07-23-2022, 09:58 AM | #10 |
Rep 152
What ended up being the cause?
07-23-2022, 10:11 AM | #11 |
Rep 149
The coolant expansion tank is shit on this car the seals opened up as well as the cap leaked out , coolant dripped down into the injectors 4 of them. The result. They changed the injectors spark plugs coils tank and cap. I really wish a aftermarket company would come out with a expansion tank that fixes this issue.
Holset274.00 |
07-23-2022, 07:31 PM | #12 | |
Rep 152
08-01-2022, 09:33 AM | #13 | ||
Rep 149
08-07-2022, 04:49 PM | #15 |
Rep 149
Yeah exactly smh
08-15-2022, 10:39 AM | #16 |
Rep 19
Coolant leak into injectors or spark plugs area is common for M5 ... happened to mine as well ... I just wanted to suggest you it might be this problem but now I can see you found it by yourself ...
