BMW 3-Series (E90 E92) Forum
CDV delete - don’t do it
07-06-2022, 01:16 PM | #1 |
Art Collector
2427
Rep 3,450
Costs way too much and didn’t even notice a difference.
Will be posting my CDV delete in classifieds if anyone wants to make me an offer.
07-06-2022, 01:49 PM | #2 |
Rep 1,199
Isn't it only $30 for the upgraded one?
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
07-06-2022, 02:08 PM | #3 |
Art Collector
2427
Rep 3,450
Lol didn’t realize people replaced their CDVs with less restrictive ones!
I was just being a jackass. I actually have a CDV delete myself. Unfortunately I have no reference point because I’ve never driven it with CDV installed, but from what I hear it’s worthwhile.
Soden82483.00 |
07-07-2022, 11:45 PM | #5 |
Rep 50
You can do it for free, just remove the cdv fully and connect the clutch line to where it connects to the next line where the cdv was. Its the same connection so no point in buying the $30 part
Torgus3781.50 AlpineBoost3927.50 |
07-08-2022, 12:33 PM | #6 |
Rep 432
The clutch delay valve restricts fluid flow when dumping the clutch quickly. When the clutch is slowly disengaged, fluid flow is so low that the CDV is not a restriction at all.
People that say there that during every day driving there is a massive difference after removal are exaggerating the effects, and people saying there is literally no difference at all obviously don't ever dump the clutch/do hard launches. Everyone seems to speak in hyperbole for some weird reason. |
e90yyc2426.50 |
07-08-2022, 01:42 PM | #7 |
Rep 2,140
Oh boy!
While you're at it, just put this next to the title: the best oil is... |
StradaRedlands4991.00 |
07-08-2022, 02:43 PM | #8 |
Art Collector
2427
Rep 3,450
Welcome to 2022 sir. Your table is right here.
(Totally agree. As mentioned I have no reference point because I deleted from day 1, but all this talk about it does make me curious. Maybe I’ll reinstall it…)
StradaRedlands4991.00 Torgus3781.50 |
07-09-2022, 10:06 AM | #9 | |
Rep 1,002
Torgus3781.50 |
07-09-2022, 10:14 AM | #10 | |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
You don't notice it if you are granny shifting. Dumping the clutch, driving wot, smashing through gears, etc. Very noticeable. Why would anyone want a valve to slow the engagement of their clutch? I need that shit to clamp down the second my foot tells it to so I don't smoke the clutch. If I want to slip the clutch in I do that with my foot not a valve. If you don't think it works, physics. If you don't notice it, go along with your day
Buug95917907.00 cooperolson64.50 |
07-09-2022, 01:07 PM | #11 |
Rep 2,529
Drives: 2011 328i Wagon
You can also just knock the restrictor out of the housing with an appropriately sized Phillips screwdriver and a couple light taps with a hammer, then put it back together properly.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
07-09-2022, 01:11 PM | #12 |
Rep 247
From experience: with CDV installed, it was ~20% of times not smooth & slightly jerky until clutch engaged. It kinda forces to let go clutch slower to get smooth going and this is mostly affecting gears 1 & 2.
It was easier to begin driving from stop with Opel Movano & VW transporter compared to BMW with CDV installed. Then again my uncle daughter had E91 MT and she didn't notice CDV existance. I did let her try my E90: short shifter + CDV delete and she did say that it is slightly easier to shift compared to her E91 but pretty much the same. I think CDV existance doesn't affect drivers that ride the clutch (because she did). And this could be reason why some notice it and others say it doesn't have any affect. Last edited by Captain Buumer; 07-09-2022 at 01:19 PM.. |
07-09-2022, 01:29 PM | #13 |
Art Collector
2427
Rep 3,450
I can’t tell how many people here thought I was being serious—LOL—but there’s some good info nonetheless.
Torgus3781.50 StradaRedlands4991.00 |
07-10-2022, 12:15 AM | #15 |
Rep 1,815
Twice the work of just removing it.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
cooperolson64.50 |
07-10-2022, 09:08 AM | #16 |
Rep 2,529
It takes ~10 seconds to do, and keeps the lines routed as BMW intended. And while irrelevant now, my car was under warranty when I removed the restrictor, so not having anything seem out of the ordinary mattered.
But you do you.
07-10-2022, 12:00 PM | #17 | |
Art Collector
2427
Rep 3,450
Efthreeoh17405.50 |
07-10-2022, 12:30 PM | #18 | |
Rep 2,529
As I have said before, while I don't feel that the difference is life altering, I do feel that it makes enough difference to take the 10 minutes to do it. Going back and forth between my two cars before I got around to doing the delete on my 128i, it was certainly noticeable to me. If you don't feel it makes a difference, then don't bother to do it.
07-10-2022, 01:38 PM | #19 |
Rep 165
I heard of a guy that removed his CDV, then the next year his dad got cancer. There's no way it's worth that risk!
StradaRedlands4991.00 e90yyc2426.50 |
07-10-2022, 01:55 PM | #20 |
Rep 1,815
Cdv delete is still a good temp fix before adding upgraded clutch in a tuned 335i. Cdv causes slipping clutches (fact not opinion) when you are driving the car hard. My clutch was having slipping issues and after the cdv delete I got another year or so from my factory clutch but still needed a new one around 150k miles. If you are tuned, you will still need a better clutch in the long run if you push the car.
Torgus3781.50 |
07-10-2022, 01:57 PM | #21 |
Rep 1,815
Lines are still routed exactly how they were from the factory. You just remove a little coupling piece between them (cdv).
Torgus3781.50 |
07-10-2022, 04:48 PM | #22 |
Rep 3,047
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
e90yyc2426.50 |
