05-28-2022, 06:56 PM | #1 |
Rep 534
Dash Cam Install
Does anyone know what fuses are constant and accessory for the fuse box under the glovebox? I have the diagram but don't know which fuses to tap into for a dashcam install. Thanks for the help.
05-29-2022, 06:04 PM | #3 |
Rep 534
There is a great guide here: https://g80.bimmerpost.com/forums/sh...php?p=28446425
but it references slot 29 for constant and 70 for accessory. Problem is that I don't have a fuse in slot 29. I suppose it is empty for a reason. BMW's are quirky and hard to tell what is constant when some of the functions will be supplied power for several minutes even after the car is shut off. I called a BMW dealership for some help and they said they could finish off the install for $150. I have absolutely everything wired except for the fuse taps. So frustrating. |
05-30-2022, 08:14 PM | #4 | |
Rep 85
05-30-2022, 09:51 PM | #5 | |
Rep 534
I live in Calgary. Trying to get some answers on the fuses as this is my last step. |
06-07-2022, 04:07 PM | #7 |
Rep 375
Some time with a multimeter will give you alot of answers. My M240 just went to 150 today, so can't give you much more than this diagram & Fuse Guide I've come across.
F46 appears to be a 12v socket, this is where I would try with an add a circuit. Last edited by Ruebarb; 06-07-2022 at 04:42 PM.. |
06-07-2022, 05:54 PM | #8 |
Rep 534
Thank you so much. This helps
06-09-2022, 06:39 PM | #10 |
Rep 85
10-15-2022, 07:11 PM | #11 |
Rep 267
10-20-2022, 09:25 PM | #12 | |
Rep 140
Drives: '23 240ix, gone: '14 Audi RS5
I plan on installing a blackvue with PowerMagicPro to a constant. It will continue to record until the battery drops below a certain voltage, at which point it will stop drawing power. |
10-21-2022, 08:39 AM | #13 | |
Rep 267
11-19-2022, 08:58 AM | #14 |
Rep 1
Has anyone figured this out?
I am buying a hardwire kit and I have the option for ATO vs. mini fuse taps. I know BMW uses both but if I know which is required for a dashcam hardwire that would save me from buying an extra tap.. |
11-19-2022, 11:29 AM | #15 |
Rep 267
I used, per the guide, fuses 29 and 70
12-01-2022, 12:49 PM | #16 |
Rep 142
'17 - Boxster 6SP/SSK/Brombacher
'23 - Polestar 2 '23 - M240 xDrive (winter car) |
12-01-2022, 01:36 PM | #17 | |
Rep 428
M240i x-drive (Thundernight, 19" 893Ms, Cognac, Pro Pack, Adaptive, Sunroof)
12-01-2022, 09:57 PM | #18 | |
Rep 267
Btw, when at home, I do turn it off (unplug power source from dashcam) as it showed me a battery drain message once. Otherwise, it's working really well. |
Invisiblename352.50 |
04-07-2023, 06:27 AM | #19 | |
Rep 428
04-09-2023, 03:32 PM | #20 | |
Rep 2,075
It drains the battery too much. I’ve had to replace batteries early because of it. The better solution is to get a battery pack and charge that when the car is running. It’s more expensive but works well and will pay for itself in replacement car batteries. Note, Blackvue have discontinued the power magic pro. |
