12-03-2021, 12:23 PM | #1 |
Rep 601
Android digital key
Android digital keys now working, as long as you have an s21 or pixel 6 device
S20ultra and Pixel 6XL support UWB (proximity and direction) like the real keys as well. Remember to start the car you need to have the phone in the charge slot area. To activate you need both physical keys, and then settings, doors, activate digital key, pop phone in, and on the s21 Samsun Pass launches and you go through the process, sure its similar on pixel 6 (different software though) Just thought I'd mention. https://www.bmwblog.com/2021/12/01/b...l-key-android/
12-04-2021, 05:36 AM | #3 |
Rep 601
Yeah, perhaps, doesn't say, does the Premier have the black credit card key? If it does then sure it should work as well
https://www.press.bmwgroup.com/globa...id-smartphones |
12-04-2021, 10:44 AM | #4 |
Rep 10
Thanks for the heads up on this - installed it for my wife on her S21 for our MSport Pro no problem, but would you use this as an emergency backup or daily instead of the key? Unless I can set up her Samsung pass.differently, it seems pretty impractical to me - unlock the phone, open Samsung pass (fingerprint required again), open the key, then hold to the door is far more hassle than just having the key on you!
Is there a way to reduce the number of steps on the phone? |
12-05-2021, 04:43 AM | #5 | |
Rep 844
I tried the black credit card, but I had to put my wallet against the door handle to unlock the door. And the phone seems to need the same actions. With the key in my pocket walking towards the car, when I’m about 3m from the car the courtesy lights illuminate. When I’m a metre from the car the doors unlock. When I walk away, the doors lock at about 2-3m from the car. |
12-05-2021, 03:53 PM | #6 |
Rep 601
Yeah it's more emergency than owt else, I just consider it the same as the black card, although on mine, I don't have to open samsung pass just hold phone to door and thumb print, and it pops open.
