10-11-2021, 10:42 PM | #1 |
20192
Rep 8,573
After installing my new turbo inlet pipe I decided I'd like to add an addition of a oil catch can
I'm looking for the perfect oil catch can for the OG M2… Something super compact Here is a picture of FTPs It's definitely a strong congratulation If you're running a OCC please post pictures of where you mounted it and what you think of it etc.
10-12-2021, 11:06 AM | #2 |
Rep 130
Drives: 2018 BMW M2
As per our other conversation just wanted to reply anyway for awareness.
My vote is still the Turner OCC. I still consider the thing as plug and play even if engine cover has to be cut. Definitely the best I've seen. Would not recommend BMS you need to do your own custom mounting and piping thing don't fit (It used to be advertised as fitting the F87). |
10-12-2021, 12:16 PM | #3 | |
20192
Rep 8,573
Post a couple pictures when you're able Thanks
10-12-2021, 01:04 PM | #4 |
Rep 1,962
Has anyone considered feeding the breather into the inlet manifold in some way?
But more seriously: If you must, just find a small K&N or similar oiled filter that will fit over the oil filler on the cam cover. The excess crankcase pressure will vent to atmosphere while the oil vapour stays on the inside of the filter. Last edited by M Fifty; 10-12-2021 at 01:11 PM.. |
10-12-2021, 01:21 PM | #5 | |
20192
Rep 8,573
An open catch can is not something I'd ever consider A baffled OCC does a really good job catching oil sludge
10-12-2021, 01:30 PM | #7 | |
20192
Rep 8,573
It's nasty regardless
10-12-2021, 03:29 PM | #8 | ||
Rep 1,644
My old Mazdaspeed3 needed one as it had a bad pcv setup and fuel dilution issues. But that was apparent looking at UOAs and 2008 oil tech. |
10-12-2021, 03:53 PM | #9 | |||
Rep 7,470
Also like I said below the occ will not catch all vapors on the n55 unless you plug the head ports and vent to atmosphere via a vented oil filler cap. If you plug the head ports and do not vent via the oil filler cap you will blow your valve cover, because there is 2 pcv sides: boost activated and vaccumn activated (taken care of by the head ports and the valve cover pcv hose where current occs attach). If you plug the head ports and do not vent to atmosphere either the vaccumn or boost pcv side (can't remember which one is which) will not work and this is bad. Quote:
To vent to atmosphere via the pcv opening on the valve cover, or a vented oil cap - you must take off the intake manifold and tap and plug each port going to the intake valves. This is bmw's "dual" exit pcv setup on the N55, you have two ways for the crank case vapors to escape - I believe one side is vaccumn operated for idling and one side is boost activated for on boost conditions. So technically even with an OCC you will not be able to catch all crank case vapors, and the crank case side where current occ's attach does not seem to produce alot of vapors in most n55's - depending on how well you followed break in procedure and how well your piston rings seal. For isntance on my m2, my pcv hose is dry even when sticking my finger inside it isn't even a bit oily, same goes for the turbo inlet pipe. So on my m2 an occ is useless.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
10-12-2021, 03:55 PM | #10 |
Rep 7,470
In summary use good oil and fuel, to ensure when fuel vapors contact oil vapors sludge doesn't form. Use an oil with low noack % (oil volatility to forming vapors) to ensure oil vapors stay to a minimum and thus minimize the amount of possible fuel and oil vapors mixing, and not super high saps oil like mobil1 0w40 which will form sluge and carbon deposits - which is why this oil is not recommended for DI cars.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 10-12-2021 at 04:35 PM.. |
///M TOWN20191.50 |
10-12-2021, 04:22 PM | #11 | |
20192
Rep 8,573
I've got much bigger fish to fry Thanks for your input
F87source7307.50 |
10-12-2021, 04:34 PM | #12 | |
Rep 7,470
Like I said before the n55 has a really good pcv system on top of bmw being reknowned for their state of the art pcv system vs. any other manufactuerer, we (n55 guys) almost always don't need an occ. Of course on some other cars that may not be the case - again depends on how you broke in your car (so for anyone that doesn't follow the break in intervals now you understand why they exist) which dictates how those piston rings bedded in and how well they seal. Because if you abused your car while it was new and the cylinder walls still have alot of cross hatches from machining, well then your piston rings are going to get beat up more and might have a bit more wear than normal, and thus now don't seal as good and you burn more oil as a result - also impacting how much pcv vapors released. Or you can be unlucky and have poor tolerances from factory.
10-12-2021, 11:31 PM | #13 | ||
20192
Rep 8,573
However I did see a little bit of oil in my charge-pipe when I changed it out
10-12-2021, 11:35 PM | #14 | |
Rep 7,470
Wait on your charge pipe? Do you mean turbo inlet? Note your factory charge pipe should be glossy inside but dry, aside from the area where bmw used their silicone lube. For me my inlet pipe was bone dry, my outlet pipe was bone dry, my intercooler hotside and cold side was bone dry literally no residue whatsoever, same with the factory charge pipe. So I am really pleased with my car, and I assume my variable rpm break in method worked.
10-12-2021, 11:37 PM | #15 | ||
20192
Rep 8,573
My charge pipe had a small amount of oil in it
10-12-2021, 11:51 PM | #16 | |
Rep 7,470
If not imo you're ok without an occ, if there is then you should look for an occ.
10-12-2021, 11:54 PM | #17 |
20192
Rep 8,573
I will let you know I haven't installed it yet
10-13-2021, 12:05 AM | #18 |
Rep 7,470
Sounds good. Generally the intercooler is where oil vapors tend to condense and pool, because of the temperature drop and the fins forcing oil droplets out of suspension - like a big oil catch can.
So if your stock intercooler has oil in it, you need an occ.
///M TOWN20191.50 |
10-14-2021, 09:11 AM | #19 |
Rep 130
Drives: 2018 BMW M2
The OCC I have is BMS with the home-depot mounting solution and random hoses LOL, I posted some pictures on your thread about turbo inlet. I read the rest of the reply, just FYI I haven't accumulated a single drop of oil in my OCC, there is just a slight oily smell in my catch can. My stock intercooler when I took it off was also bone dry. I also think where the OCC needs to go on our cars above the exhaust/turbo, it gets way too hot. During the summer I took some temp readings the OCC sits at a minimum at 100C and during auto cross I got as hot as 120C. Not that it would vaporize engine oil on paper but I'm sure anything accumulated probably weathers off the fumes out of the catch can (Like how you don't need 100C to dry a wet towel).
10-14-2021, 12:01 PM | #20 | |
20192
Rep 8,573
I saw your post but without better lights it's very hard to see yours at all besides the brackets I'm looking at turners because of the well thought out design and their mounting brackets are on point w a perfect installation
10-14-2021, 01:42 PM | #21 |
Rep 1,962
Why would you care how hot it gets? It's there to collect anything that the engine vents, rather than feeding it back into the inlet tract where deposits might restrict airflow. If it doesn't create oily odours in the interior, I'm not seeing a problem if it evaporates compared to being (partially) burnt and vented via the exhaust...
10-14-2021, 01:53 PM | #22 | |
20192
Rep 8,573
It's not going to be an issue
