BMW M3 and M4 - The Icons
home
Technical Sections Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      06-24-2021, 05:55 AM   #1
PLife
PLife's Avatar
Drives: X5 M50i, G80 M3 xdrive
Gear ratio calculations 6MT vs ZF8
Thought this is interesting… The ratios are so short on the ZF even compared to the manual (which has normal ratios in my opinion). >10% shorter 1st gear, >20% shorter gears 2-4.
NCG80M3663.50
NicolasB808.00
baron951703.50
      06-24-2021, 06:15 AM   #2
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
What's your point ?
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      06-24-2021, 06:25 AM   #3
PLife
PLife's Avatar
Originally Posted by PLF69 View Post
What's your point ?
Nothing specific. These are the top speeds in each gear based on ratio calculations and thought people might find it informative. The short ratio zf was surprising as it might be a bit too short
      06-24-2021, 09:02 AM   #4
PLF69
PLF69's Avatar
3768
Drives: 2023 M3
Ok, thanks for posting the info.
There is more to the final experience than the what we see doing the number crunching, the overall feel of a car can be very different with just a simple ratio change.
I attended a 2 day track event last weekend with my new to me M340i wich is equipped with the ZF8 (probably similar to the one in the M3) and I did not feel any disconfort with the gearing. I remember not liking the gearing in my M235i. I also drove a Manual M2 and a DCT on the same track, same day and the feeling was quite different.
I also often fall into spec hunting and over-analyzing but when I finally test drive and do serious driving with the cars I often realize that the perspective I had in mind is a lot different than what I feel in reality.
Daily: 2023 X5 45e
      06-24-2021, 09:07 AM   #5
PLife
PLife's Avatar
Completely agree. My 718 spyder has been criticized by literally every single car reviewer for having obscenely long gears in the manual. I actually find the long gears super enjoyable and never lack for power. In fact the manual is faster on a roll than the pdk if you shift fast enough (started a dragy thread on rennlist confirming this). Whereas on my R8 v10 plus the gears were obscenely short and i hated it, occasionally found myself banging off the rev limiter in manual race mode unless i had a triple venti macchiato
PLF693767.50
      06-25-2021, 01:29 PM   #6
frankiebones
frankiebones's Avatar
5299
Drives: Fire Orange G80 6MT
What's your point ?
i find this to be very helpful. i like to know top speed/gear as a 6MT driver.
Fire Orange 6MT G80 (Miss July, 2021 Cover of Bimmerpost)
SMB M3 CS (gone)
YMB F80 6MT (gone)
PLife647.50
      06-25-2021, 02:32 PM   #7
PLife
PLife's Avatar
Thanks man. Me too. I calculated these using the 20 in rear wheel tire diameter so if you find that they are off please let me know and i can update it. But it should be pretty close
      06-25-2021, 02:58 PM   #8
speedyman
Drives: 2021 X5 M50i, 2016 Z06
The across the board criticism of the 718 Spyder and GT4 is correct and that is why there is uniform agreement throughout the automotive press. The gearing is waaaaay to long for the street where these cars will see the majority of their miles regardless of the marketing hype about them being track/race cars. Might as well put an old 2 speed Powerglide in there. LOL.
PLife647.50
      06-25-2021, 03:07 PM   #9
PLife
PLife's Avatar
If you wanna drive speed limit this is true. But keep that car over 6k and youre hauling balls. With long tube headers it keeps up with a .2 gt3 and wakes up dead people in the process. Also you dont need to shift that much since the top speeds are approaching the limits of coordination.
      06-27-2021, 01:50 PM   #10
SwissG80
Nothing much
Switzerland
Drives: BMW G80 M3 Competition
What I dislike about the ZF GS6 is that the ratios are just terrible. The gap from 1st to 2nd is huge, I feel it really puts the engine out of the powerband (even though said powerband is huge), even when shifting at redline. Similar story with the 2-3 shift.
And then the 4th, 5th and 6th gears are much closer - too close in fact - which really doesn't make sense on a turbocharged car with such a broad powerband! For a high revving naturally aspirated engine like the E92's S65 (which used the same exact gearbox and ratios afaik, as did the F80), sure.
In my mind, the old Getrag 420G in the E46 M3 (and the EUDM 3.2 E36 M3) had perfect ratios. Another excellent set of ratios comes from Honda's K-Series (Type R / Si) gearbox.
And this issue also affects the Alfa Romeo Giulia QV, which uses the ZF S6-53 which has the exact same ratios as the GS6.
One of the things that made me choose the Competition over the standard M3.
PLife647.50
g80
