BMW 3-Series (E90 E92) Forum
"Jumpy" idle
05-16-2021, 08:03 PM | #1 |
Novice Enthusiast
15
Rep 75
Drives: 2010 BMW 328i e92 ULEV 90k
Garage List 2010 BMW 328i x-Drive [0.00]
2012 Ford E-350 [0.00] 2009 Cadillac DTS LUX [0.00] 2003 Mercedes Benz ... [0.00] |
"Jumpy" idle
Hi I've seen a couple of posts about this but it seems that my car does something different than everyone else's. Most times when I start my car on a cold start it starts and goes to 1,000RPM for a second before the computer figures everything out and it goes to 500-700RPM. As soon as it equals out it oscillates (best word I can come up with) between 600-800RPM until it chills out and smoothens.
Could this be something serious or is it the computer just fluctuating the RPM to find the "just right" spot.
10 328i 6AT (GM 6L45) AWD
03 SLK 230 5AT RWD 09 DTS 4AT FWD 12 Ford E-350 |
05-16-2021, 09:10 PM | #2 |
Art Collector
2427
Rep 3,450
Subbed for results. I have this exact problem sometimes. Doesn’t seem to fit the description others with “jumpy” idles.
05-17-2021, 10:11 AM | #3 |
Rep 4,330
the computer does not hunt for RPM speed unless it's having problems controlling it.
mine idles up for the cold start, then idles down and stays rock steady. check and clean the vanos solenoids and screens, check for vacuum leaks and un metered air, check valvetronic things. edit: and if you've got a disa manifold, check the disa motors. |
Dave92N54528.00 |
05-17-2021, 11:16 AM | #4 | |
Art Collector
2427
Rep 3,450
05-17-2021, 11:18 AM | #5 | |
Rep 4,330
but the hackjob garage method is to spray something combustible where you suspect there might be a leak and listen for the idle speed to change. I built a paint can smoke machine because I got tired of wasting time with other methods. |
05-17-2021, 12:31 PM | #6 | |
Art Collector
2427
Rep 3,450
I have a smoke tester (ghetto paint can one too) sitting in my garage but I havent gotten around to this yet. I feel like the smoke it puts out isnt thick enough to be easily detectable, but maybe Im wrong.
05-17-2021, 03:29 PM | #7 |
Rep 4,330
basically.
just make sure it's regulated to 1-2PSI so it doesn't blow everything apart and hook it up. if yours isn't making enough smoke, decrease the ohms on the element and it gets hotter. Mine takes 6-7amps of current IIRC. |
05-17-2021, 06:17 PM | #8 | |
Novice Enthusiast
15
Rep 75
05-17-2021, 08:07 PM | #9 |
Rep 4,330
a small intake leak is proportionally a much larger leak at idle than at WOT.
likewise you need the valvetronic to be it's most accurate at idle, because you're dealing with tenth of a mm things. |
05-22-2021, 08:58 AM | #10 |
Novice Enthusiast
15
Rep 75
Okay so I wanted to give an update. I unclipped the vanos and wiped them down really well. I haven't had the issue since. Having said that, I live in Allentown PA which is getting warm right now. Above 55 at night. I have no idea what was happening but it's not happening anymore. I'll give another update when I get my VCG replaced. I know that will probably not have an effect on idle but I can have the tech that's doing it check other things like vacuum leaks etc.
05-22-2021, 09:34 AM | #11 |
Art Collector
2427
Rep 3,450
Thank you for following up. I'll try cleaning my vanos solenoids again but I did a few years back and not sure it made any difference. That said it's free and takes 10 minutes.
Keep us posted on the outcome of your VCG and anything else you find!
tgeho_e9215.00 |
05-22-2021, 07:11 PM | #12 | |
Rep 169
05-22-2021, 08:16 PM | #13 |
Rep 13,122
Coils and Plugs
A coil starting to go bad can cause a jumpy idle it may not throw a code yet but it is on the way to failure . Especially accompanied by gas milage loss and power loss. There are other things that will cause it to but if your car is past 70k on a N52 or N51 it is something to take look at. I just went through this . It was jumpy then cylinder 6 finaly failed . I had changed plugs about a year ago. |
tgeho_e9215.00 |
05-22-2021, 09:06 PM | #14 | |
Novice Enthusiast
15
Rep 75
Edit: I just checked my mileage. I get 25 mpg average. Extra-Urban conditions.
05-24-2021, 06:38 PM | #16 |
Rep 1,199
Good to see you fixed the issue. A vacuum leak would cause those symptoms you were having and could be worth just replacing them for peace of mind since it takes about 20-30 minutes to do and costs less than $20.
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
08-13-2021, 07:57 PM | #17 |
Novice Enthusiast
15
Rep 75
*UPDATE* I got my valve cover gasket replaced by a local Indy shop known for BMWs. As it turns out, I had a massive leak that most definitely caused the uneven idle. I had it done 4 days ago and the problem no longer persists. Actually I feel like the acceleration from stop is SIGNIFICANTLY smoother. I initially thought that was cause by my transmission. Funny enough that even seems smoother…. Probably in my head but all around a significant increase in stability and performance.
