04-25-2021, 11:29 AM | #1 |
Rep 44
Summer wheels/tires installed. f/r 265/295
I finally got around to installing my summer wheels and tires.
Front: 19x9.5" ET28 with 265/30-19 tires Rear: 19x10.5" ET45 with 295/30-19 tires I'm on stock suspension without any spacers. After about 120kms of driving I haven't seen, heard or felt any rubbing at all. I do like the stance as of right now but I do have Eibach springs that I'm planning to install this week that will get rid of some of the wheel gap and I'm hoping I continue to not get any rubbing but I'll report my findings. |
04-25-2021, 10:03 PM | #2 |
Rep 357
Drives: 2018 M2 Road & Track Build
The car and the wheels looks great!
However looking at the last picture on how much the tire & wheel sticks out the fender, you'll probably going to experience rubbing on HARD full compression. I had a similar set up in 19s before Titan7: 19x9.5 et22 & 19x10.5 et34 on 265/35 and 295/30 Michelin Ps4s Tires as well and it was rubbing like crazy with -2.5 camber in the rear with only 1/5 -1/4 inch lowered. My car was also on Ohlins R&T which is CRAZY stiff in the rear (1086 lb ft Ohlins spring vs whatever stock had, rear 14clicks shocks setting. 20 softest and 0 stiffest) I know ur ET45 is gonna sit 11mm inside than my et34 but ur 3rd picture actually looks almost identical to my setup. But since ur on stock ride height u might be fine. I sincerely hope u dont rub tho |
04-25-2021, 10:56 PM | #3 |
Rep 44
Thanks for the detailed reply. I'm going to have to take a super close look once I have the springs on. Worst case I throw the stock springs back in.
Love your pics and car! The second pic, is that a matte black wrap? Or lighting? (picked up photography recently, still lots to learn) |
04-25-2021, 11:20 PM | #5 |
Rep 44
That does make me feel a bit better hah! Thanks Matt. Do you happen to have any pics you could post of that setup? If not, no biggie, I'm hoping to have my car up on the lift tomorrow night.
04-26-2021, 10:09 AM | #7 |
Rep 4,145
Drives: '18 M2 6MT
Looks pretty good. I like to match the tire crown, so for me it's 285/30 in the rear, but these don't look bad.
04-26-2021, 11:22 AM | #8 |
Rep 166
Does anyone know if 265-30-19 and 285-30-19 would fit on 763M wheels without rubbing? Stock suspension.
2013 Toyota Tacoma - TRD Pro Wheels, Bilstein Leveling Kit
2021 BMW M2C Special Content |
04-26-2021, 12:22 PM | #9 |
The Seeker
14075
Rep 3,376
They will fit, no rubbing, and fit fantastically. It's the size the car should have come with IMO. The Edelweiss LT°5 have a more aggressive offset front and rear, (+20/+33) and come with these size options without issues.
04-26-2021, 12:23 PM | #10 |
this is the way
18403
Rep 8,577
04-26-2021, 01:05 PM | #11 |
Recovering RS4 owner
297
Rep 266
my apologies, I thought you had Apex EC-7s for some reason (same specs though). Here's a pic anyway
04-26-2021, 01:23 PM | #12 | |
Rep 44
Thanks for the pic. Those rims look like they don't poke out as far as mine, but I do like the drop. |
04-26-2021, 01:50 PM | #13 |
Rep 55
Hey Matt, when you say "same spec", are you implying that you're on stock suspension or you have Eibach springs installed? Whatever you're on, setup looks perfect from this angle!
04-26-2021, 02:27 PM | #14 | |
Rep 357
04-26-2021, 03:19 PM | #15 |
Rep 44
04-26-2021, 03:42 PM | #16 | |
297
Rep 266
Front: 19x9.5" ET28 with 265/30-19 tires Rear: 19x10.5" ET45 with 295/30-19 tires I'm running PS4S tires and Eibach Pro-kit springs on stock dampers |
04-26-2021, 05:11 PM | #17 | |
Rep 44
OEM numbers: Front: 33-53-6-784-122 Rear: 31-33-6-776-144 But I might just leave the stock ones if rubbing isn't an issue. |
Matt Devo296.50 |
04-26-2021, 05:25 PM | #18 |
Rep 44
Found the original thread about short bump stops to keep the travel the same so the ride isn't as harsh.
https://f87.bimmerpost.com/forums/sh...84-122&page=14 However, I'm not sure if this applies to my specific setup or not. The car is going up on the lift in about an hour so I'll report back my findings. |
04-26-2021, 09:39 PM | #19 |
Rep 44
Only got to installing the rear springs tonight. Went for a little drive and no rubbing at all yet. I know springs take some time to settle and I don't have the fronts installed yet so we'll see how everything is tomorrow.
04-27-2021, 01:00 PM | #22 |
Rep 44
