BMW 3-Series (E90 E92) Forum
Alternator going bad??
03-22-2021, 11:16 AM | #1 |
Rep 2
Hello, I drive a 2008 328xi with a 6 speed. Lately I have been noticing a surge in anything electrical related, during idle and during normal driving, regardless of throttle and RPMs. The blower motor, headlight, and music seem to be effect the most by this. This issue has been present for the last week or two, but has been getting worse the last few days, including the headlights starting to surge and audio cutting out. I will going on a long road trip at the end of the month and figured I should get this sorted out by then. Any help is appreciated, thankyou!
03-22-2021, 05:25 PM | #2 |
Art Collector
2427
Rep 3,450
What codes are present? If it’s an over-voltage situation there will be a DTC stored.
What do you mean by surge? Your lights become brighter and your music becomes louder? Also what’s your mileage? Any other history? You live in the States: Is that Alaska or Florida? All of these details matter and will help you get this resolved. Beyond the need to pull codes, I would start with the basics and check voltage with a multimeter. If you don’t have one you can use the BC hidden menu to check this, but personally I would hook up my meter to battery in the trunk, turn on min/max, and go for a brief drive. Could be voltage regulator. Fortunately that’s a cheap fix. Need more info though.
03-23-2021, 07:53 AM | #3 |
Rep 1,080
You need something like this to monitor the voltage while driving:
https://www.amazon.com/Palumma-Charg...6503919&sr=8-3 |
03-23-2021, 09:22 AM | #4 |
Rep 733
If your OBC display is non-shitty (unlike mine) , you can enter the hidden menu, as e90yyc said. Here are some more details.
navigate to 19.00 "LOCK" enter the sum of the last five digits of your VIN navigate to menu 09.00 where you can monitor Voltage as seen by the cluster For more information on how to enter the menu and how to navigate, search "e90 hidden menu" online. This is of course, assuming the cluster does not become unusable whenever the power surges. I hope this helps. Some fluctuation is normal, though I'm not sure how much. Mine sits around 14.1-14.5 at idle, bouncing around a bit, and can briefly dip as low as 12.5 during driving conditions. |
Tags |
alternator, electrical, surging |
