BMW E46 M3 - Legend Eternal
home
E46 M3 Marketplace Owners Classifieds E46 M3 For Sale / Wanted
      11-08-2020, 08:47 PM   #1
HenryChinaski
Drives: Oxford Green E46 M3
2003 BMW E46 M3 Laguna Seca Blue Slicktop 38k miles
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
Now live on Bring a Trailer - 2003 E46 M3 Laguna Seca Blue!
2003 BMW E46 M3 LSB Slicktop 38k mile
2003 M3
38400 miles
Laguna Seca Blue
Black Nappa Interior
Manual
HK Stereo
No sunroof (slicktop)!
Xenon headlights
Cold Weather package
19” Style 67 wheels
Power memory seats
2 Owner clean Carfax
Have maintenance records
Located in Minnesota(car has not seen a winter)
Extremely clean example overall - one small door ding and two spots on the rear bumper were touched up while in the care of the previous owner(by hand, not resprayed). Rear bumper looks to have been repainted(its been wet sanded), color match is correct as both bumpers and side skirts are all very slightly more green due to flex additive. The rest of the car looks perfect and has the correct amount of “orange peel” that BMW is known for, no overspray found between any panels nor signs of removal. All VIN stickers are in place, as well as all window branding. Very few chips in the paint, and no noticeable deep scratches. Paint has been maintained, corrected, and coated with Gtechniq CSL ceramic coating. This is a Minnesota car but has never seen winter and not much rain, underbody is very clean with all the original spray coating intact. No cracks in the rear subframe, but always something to consider getting done if you plan on driving the car spiritedly. VANOS bulletproof was just completed along with valve adjustment - its a very quiet S54 at the moment!
Car was originally SMG, but I also just completed the manual swap so everything related to shifting the car is new. Most people call this a manual transmission swap, but really its just a shift linkage swap. SMG shifter comes out and manual shifter and pedal goes in, so the transmission is completely original. Clutch was like new so I did not change it, better to keep the unit that’s broken in the flywheel.
Recent Maintenance(last 100 miles):
-Full VANOS bulletproof using Biesan parts
-Valve adjustment
-Valve cover gasket(BMW)
-Engine air filter (Mahle)
-Cabin Air Filter (Activated Charcoal version)
-Spark plugs(NGK)
-Coil packs (all using Bosch)
-ICV cleaned
-Brake fluid flush(BMW fluid)
-Oil change (Castrol)
-Transmission fluid change(BMW Fluid)
-Rear differential fluid change(BMW Fluid)
-Front Control arm Bushes (Lemforder)
-Accessory and AC belts (Gates)
-Both headlight bulbs
-Sway bar bushings lubricated
-GM5 Module repaired with new relays(Door lock controller)
Modifications:
-Autosolutions 0% Short Shift Kit (same height as oem)
-Coby wrapped steering wheel
Look for the car on BaT in the coming weeks
Videos:
https://youtu.be/2a8pis9yJ_M
https://youtu.be/fwLRZfv9Vxo
https://youtu.be/PQ8SOkQCem8
https://youtu.be/EeE0UtscEn8
      11-08-2020, 08:52 PM   #2
HenryChinaski
      11-08-2020, 10:08 PM   #3
to_riffic
to_riffic's Avatar
Drives: rwd
damn....that's prestine. GLWS!!!!
~loud noises~
      11-09-2020, 10:09 PM   #4
Mar48
Mar48's Avatar
1100
Drives: '22 M3 Comp xDrive - Atlantis
Bump for a fellow Minnesotan!
IG: SirLanzelotte
Individual Atlantis Metallic G80 M3 Competition xDrive
2015 Audi Allroad P+ Brilliant Black/Black
Past: F80 M3/Z4MR/E46 M3/Z4MC/Z3MR/335Xi
      11-16-2020, 11:39 PM   #5
dangyi
Drives: 2013 M3
Go to BAT for the top $$$.
      11-17-2020, 07:36 AM   #6
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
This would decimate all on BaT...Crazy to think there are still examples like this floating around even 15+ years later
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
      11-19-2020, 12:16 PM   #7
HenryChinaski
Thanks all for the comments!
Quick note - I found out BMW sent me the wrong clutch switch causing the cruise control to not function(the car thinks it works so no codes came up). This was an error on their part as they erroneously superseded the correct part. New switch on the way
      11-21-2020, 02:26 PM   #8
mstacrz
Drives: F80 M3 & 997 GT3 RS
Bump to my fellow LSB M3 and 6 spd.
Clean car my friend.
      11-25-2020, 03:36 PM   #9
HenryChinaski
Looks great!
No longer a feeler, car is for sale with price adjusted
      01-01-2021, 05:18 PM   #10
adam996GT3
Drives: F80 M3
Price?
      01-01-2021, 05:29 PM   #11
AvusBlueF80
Drives: '18 avus blue m3 zcp
Price?
      01-02-2021, 02:30 PM   #12
wrk.eat.drive.rpt
Drives: 2016 340i, 08 e92 m3
Interested please dm
      01-08-2021, 11:46 AM   #13
HenryChinaski
Updated, not sure what happened but after the new year started receiving a lot of offers.
Car is only available through the coming auction on Bring a Trailer
      01-08-2021, 04:53 PM   #14
to_riffic
to_riffic's Avatar
Drives: rwd
Exciting! I wonder if this will eclipse the might #90k '03 LSB that sold back in '19 on BaT.
~loud noises~
      01-08-2021, 07:39 PM   #15
ziak1
Drives: 2004 E46 M3
what a stunner ! GLWS!
      01-15-2021, 03:58 PM   #16
HenryChinaski
Auction is live, link at the top!
e46m3
