BMW 2-Series Gran Coupe
BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      09-27-2020, 08:33 PM   #1
mblaucoupe135
Drives: 2022 M240i
JB Plus quick install
has anyone tried this on their m235i GC yet? seems like an easy and cheap way to add a bit more power.
https://burgertuning.com/collections...-install-tuner
      09-28-2020, 07:49 PM   #2
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
Yup have it on mine with great success so far.
      09-28-2020, 08:55 PM   #3
CyberYYZ
Drives: BMW M235i
How much more power?
Curious if you see an improvement with your 0-60 times?
If so how much better?
      09-28-2020, 09:03 PM   #4
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
Dropped 2 tenths.
      09-29-2020, 07:29 PM   #5
mblaucoupe135
Drives: 2022 M240i
that's good to hear! glad you are liking it. do know if you needed the 3 wire or 4 wire version?
      09-29-2020, 11:45 PM   #6
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
You need the 4 wire as sold on the website listing.
      09-30-2020, 06:46 PM   #7
mblaucoupe135
Drives: 2022 M240i
interesting as the guy from Burger sold me the 3 wire version! I imagine once I get access to the sensor it will be pretty clear that the 3 wire one won't even fit. is that right?
      10-01-2020, 10:16 AM   #8
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
See here
      10-01-2020, 07:15 PM   #9
mblaucoupe135
Drives: 2022 M240i
See here
yeah I saw that too so I reached out to Burger to make sure I was getting the right one and the genius I talked to said that was referring to the m235i with the N55 engine and I needed the 3 wire one.
can you confirm that the sensor you plugged into has 4 wires/pins so the 3 wire one i got wouldn't even connect to it? that way I can prove it to the guy he sold me the wrong one for my m235i gc.
      10-02-2020, 08:03 AM   #10
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
See here
You don't have to prove anything, you tell them it's a f44 235i. It's also on their website as I already showed you.
      10-02-2020, 11:39 AM   #11
mblaucoupe135
Drives: 2022 M240i
See here
thanks, I appreciate your help!
      10-03-2020, 06:47 AM   #12
Saladin12
Saladin12's Avatar
Drives: On Order - 218i M Sport
Does anybody know if these tuning boxes invalidate the warranty??
      10-04-2020, 06:38 AM   #13
knali8
knali8's Avatar
Australia
429
Drives: 2021 X3M Comp
I had a similar issue when searching for a tuning box for my m135i even after i gave them the f40 code, they still sent me the wrong box, for the previous n55 engine.
Good luck.
      10-04-2020, 02:00 PM   #14
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
No it's plug and play. It is essentially a boost controller. The plug has a resistor in it and what it does is increase resistance in the map sensor reading to fool the dme into thinking it's not getting the boost it's requesting. In turn adding boost.
      10-04-2020, 06:41 PM   #15
mblaucoupe135
Drives: 2022 M240i
I forgot to ask you any issues yet like check engine lights? also, did you keep it at the default setting it came set at or did you turn it up?
      10-05-2020, 06:09 AM   #16
BlownLSX
BlownLSX's Avatar
Drives: C6Z, X3MC
No cel, I maxed out the dial in the 4 o'clock setting.
      10-05-2020, 02:06 PM   #17
Saladin12
Saladin12's Avatar
Ah that makes sense! I assume the same applies to the Racechip boxes? https://www.racechip.co.uk/shop/bmw/...3kw-220nm.html
      10-05-2020, 09:00 PM   #18
mblaucoupe135
Drives: 2022 M240i
nice!
bmw
