BMW 2-Series Gran Coupe
BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      08-04-2020, 10:14 AM   #1
mblaucoupe135
Drives: 2022 M240i
tire question
I am thinking about replacing the run flats that came on the car with a regular tire. i have the 18" wheel style 554 with 225/40 tires. Does anyone know if you can run a 235 tire of the car without any rubbing issues? would like to give the car a bit more tire for more aggressive cornering!
      08-04-2020, 12:38 PM   #2
J-RO
Drives: BMW M240ix
T
Go to the Tire Rack website. They may offer alternative sizes.
      08-04-2020, 01:48 PM   #3
mblaucoupe135
Drives: 2022 M240i
Originally Posted by J-RO View Post
T
thanks for the suggestion, but I already tried that and couldn't figure out for sure if this would work or not.
      08-05-2020, 12:11 AM   #4
LaVitaEBella
Drives: 2016 BMW M3
How about consulting Google? I am sure that you can find a lot of suggestion from this search engine?
      08-05-2020, 05:17 AM   #5
J-RO
Drives: BMW M240ix
Did you go to this page?
https://www.tirerack.com/tires/Selec...Standard+Tires
      08-06-2020, 05:31 PM   #6
Gregus330i
Gregus330i's Avatar
Drives: BMW 330i M Sport
A 235/40 do you mean? Or 235/35? Because if you put the latter on an 18" wheel your speedo will be incorrect. Plus you won't get more aggressive cornering on a 235 tyre as opposed to a 225. Your first priority needs to be what tyre - something like Michelin Pilot Super sport will give you aggressive cornering, in the standard 225 size
      08-06-2020, 07:06 PM   #7
mblaucoupe135
Drives: 2022 M240i
yeah 235/40 is what I was thinking. and yeah the type of tire is clearly important too so I would be looking to do more of a high performance summer tire on it. but a 235 over a 225 gives you 10 more mm of tire width on each side which should help in cornering and look cooler as well!
      08-06-2020, 08:48 PM   #8
Gregus330i
Gregus330i's Avatar
Yes, I understand. If you want cooler looks, a significant visual improvement of stance and width of car would be to add 10mm spacers. I did on my M135i Xdrive F40 which is basically the same car chassis wise as the F44. Unfortunately these cars do look 'skinny' at the wheels, especially the front. A wider tyre will make no difference at all visually - It's a wider wheel offset what you need, hence the spacers. I bought H&R magnesium alloy ultra lightweight ones and am very happy with the way they make the car look more muscular, wider, as I've added 20mm width to the wheel track
      08-06-2020, 08:51 PM   #9
mblaucoupe135
Drives: 2022 M240i
yeah that's a good point about spacers. I run a set on my m240i during the winter when I have the stock wheels on. am I getting greedy if I want wider tires and spacers?! lol
      11-29-2020, 01:05 AM   #10
Ian T
Australia
Drives: BMW M235i x drive F44, 330D E
235 tyres rubbing issues
BMW supply 235/35ZR19 in Australia, I have had a rubbing issue with these tyres on the M235i x drive (F44), front fender and wheel well liner damaged (fender lip pulled down by the tyre resulting in slight distortion on the bodywork plus fender pushed out a few mm) wheel well liner also cracked. This occured while driving on a sweeping left hand bend with an undulation in the road. The m235i absorbs the undulation much better than my E90 330D indicating that the suspension does a lot of work to isolate the car body. Unfortunately the result was wheel to car body interference. Should not happen when the tyres, rims, suspension etc are stock.
Cheers.
bmw
