07-10-2020, 02:43 PM | #1 |
Rep 342
Drives: G20 330ix M Sport
Retrofitting Wireless Charging
Has anyone retrofitted the genuine wireless charging in their F44? I see everyone with G20 3 series are retrofitting from the NFC module to the wireless charging module. The only coding is for the don't forget phone. They are saying it is plug and play were the NFC will still work.
07-11-2020, 06:25 PM | #3 |
Rep 339
There is most likely a retrofit for adding it later as BCM is the same in across all models. It will require reprogramming if it is possible. However it might not have the harness plug. Won't know until you take it apart.
02-20-2021, 09:07 AM | #5 |
Rep 231
04-14-2021, 11:56 AM | #9 |
Rep 261
Part arrived today from Germany.
took a gamble on how to fit it by using more brute force than I wanted to, but absolute piece of cake, took me about a couple of minutes. Wireless charging now in place, not fussed about getting the warning coded in, won't need it. |
04-14-2021, 11:58 AM | #10 | |
Rep 5
What's the part number you ordered? |
04-14-2021, 12:48 PM | #11 | |
Rep 92
Drives: 2023 BMW 330e Xdrive
ScottC25109.50 |
04-14-2021, 01:31 PM | #12 |
Rep 261
Basically, once you take the removable lip off it's easy.
I just used long nosed pliers to pull on the part that the removable lip attaches to. Did this on both sides, and the front of the existing one came off. There were then plenty of places on what's underneath to grip with the pliers to pull it straight out. Take the plug out the back, plug it into the new one and that's it. I tested that it worked before pushing it fully back into place. Someone posted a link on here for a guy in Germany selling them on eBay. Have a good look as he has them advertised at different prices. |
AlpineAl2782.00 Tyr031.50 |
12-30-2021, 03:16 PM | #13 |
Rep 4
Folks, could you please let me know if you were able to use BMW digital key before retrofit?
My BMW digital keys has been removed from my setup and I'm wonder if I will add this wireless charger it will automatically added bmw digital key feature? How complicated is connecting this part? |
01-06-2022, 05:38 AM | #14 |
Rep 4
Has anyone added a wireless charger to their car? My car was produced without wireless charging.
I saw that is is possible to buy an OEM wireless tray (5A0E551) but I am not sure if the car that did not have this tray will have a bundle of cables to mount it? Additionally, anyone knows if it possible retrofit of BMW DIGITAL KEY? My car was also produced without that key with information „32Z ENTFALL BMW DIGITAL KEY”. The car has an NFC handle on the driver's side. I wonder if I add a wireless charging tray it will help with the bwm digital key or this needs to be activated on bmw connected drive servers? |
01-30-2022, 12:53 PM | #15 | |
Rep 118
02-25-2022, 05:02 PM | #16 | |
Rep 5
I have also ordered mine online from a German seller. |
02-25-2022, 08:06 PM | #17 |
Rep 118
Hey there if I may ask how much did you pay? Also do you have the NFC on your door? I have NFC on my door handle, and my car was supposed to be equipped with the digital key but it was removed due to the chip shortage. I’m thinking to buy an OEM wireless charger and was hoping I could have a friend help me code a digital key in
03-03-2022, 12:57 PM | #18 |
Rep 762
Drives: '23 BMW i7 xdrive60
Can someone message me on parts needed and supplier?
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue |
04-12-2022, 02:37 PM | #19 |
Rep 5
jettie1767143.00 |
06-07-2022, 11:44 AM | #20 | |
Rep 55
Thanks |
07-01-2022, 08:57 PM | #22 |
Rep 7
M235 Wireless Charger Mod
I had the issue where my S21 Ultra did not properly fit and the wireless charging was unreliable in a 21` M235i. Here are some images to help understand the parts and assembly/disasembly.
