03-05-2020, 06:25 PM | #1 |
Rep 17
M235i Stage 2 (Bootmod3) Logs
Backstory:
I recently installed a stage 2 kit on my M235i including an intake. I was having some issues with a "Mass air too high" and "Running too rich" CEL codes. Some hiccups and stuttering at light throttle/low RPM applications. I swapped back to the stock intake with a K&N dry filter, because I found out that these cars don't really play well with intakes that aren't in a closed box. Car seems to run much better. Although, I still get a "Mass air too high". I also got told by ProTuningFreaks that the octane in my car wasn't up to snuff and I should run a 91 octane tune instead of a 93 octane tune. Present: I flashed to a 91 octane tune and wanted to share my logs for some feedback. Full pull: https://www.bootmod3.net/log?id=5e61...0b43598fdf16fc Some normal driving with some light pulls: https://www.bootmod3.net/log?id=5e61...0b43598fdf16fd Is there an issue with my Ignition Timing? |
03-07-2020, 06:17 PM | #3 |
Rep 17
I found an o-ring on my old chargepipe. WHOOPS.
I put it on the new one and it seems to be a much tighter fit. I did another pull and my STFT is even higher now…. 1.26 at it’s max I believe. This is what I was attempting to fix, and it got worse?! https://www.bootmod3.net/log?id=5e64...0b43468a76b9df Any input..? My timing seems better, but there is inconsistency on cyl 3. |
Jaysmyname0.00 |
03-07-2020, 11:12 PM | #4 |
Rep 1,115
Your latest log is good, I would consider swapping the ignition coils between #3 and #4 to see if the problem moves. That would tell you if it's the coil or not.
03-08-2020, 12:29 AM | #5 | |
Rep 17
The STFT is high on my last log. I'm still trying to figure that one out. The only connections between the bolt ons I installed that I haven't checked yet is the downpipe. Is that something that could even cause the STFT run all the way up to 1.2-1.3? |
03-08-2020, 12:46 AM | #6 | |
Rep 1,115
03-08-2020, 08:19 PM | #7 |
Rep 17
Update
I essentially reinstalled my entire chargepipe, made sure the o-rings were good, and tightened the top of my downpipe.
My logs look way better: http://www.bootmod3.net/log?id=5e6589dad10b43468a76cb69 I noticed the throttle angle dipped hard though while I had it at 100%. What's up with that? STFT looks so much better, but I still see areas of 1.05+. Perhaps the downpipe needs tightened even more. I only got about 1 full turn on the bolt because it seemed really tight already. EDIT: Looks as if the throttle angle dropping is because of a little bit of overboost. Last edited by Sliptality; 03-08-2020 at 08:45 PM.. |
08-14-2020, 08:40 AM | #8 | |
Rep 242
09-12-2020, 02:28 PM | #9 | ||
Rep 15
09-12-2020, 05:26 PM | #10 |
Rep 15
Here's my log on bootmode stage 2 93 (AGG)
I also saw that on the log it read knock of 1 but idk if that was because of the gear i was in giving it WOT. If you guys can tell me if you see anything wrong here let me know thanks. https://www.bootmod3.net/log?id=5f5d...729b7e93a830dc |
Tags |
bootmod3 tuning, datalog, ignition timing, mass air flow, stage 2 tune |
