      08-20-2008, 06:53 PM   #1
rockmed
Drives: none
USB Interface
Are the cables supposed to come with the factory installed USB Interface? It's not clear in the manual if they are included or not. Further, why do you need AUX cable for the audio to go through from an iPod? I would think the USB interface alone should do the trick.
What is strange is you can supposedly connect a USB memory stick. However, what's the point if you must use a separate AUX cable and the USB sticks don't have audio jack?
      08-20-2008, 07:02 PM   #2
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
The car should come with the cable. the 6FL adapter includes the cable.
I will attempt to answer your other question.
A typical iPOD has a wide connector in which the cable provided by Apple will connect to a computer's USB connection. The cable provides power, audio, a music selection data.
However, when BMW designed the 6FL interface, they wanted to accomodate three technologies.
1. An iPOD
2. USB stick
3. Generic MP3 player
To avoid having to design multiple interfaces they came up with a clever design.
The separated the data signals on a typical iPOD interface jack, with USB, and the DIN8 audio connector. Essentially splitting the iPOD output into two paths although one cable.
Now if you use another music player that supports USB or just the audi jack, or both, you can still connect it and get some or full integration with the head unit.
Had they one implemented the IPOD connector to USB connection, no other technology, USB stick, or generic music player would have worked.
BMW knows that for cars, USB sticks will be a dime a dozen, and there is no sense keeping an expensive iPOD in your car.
2011 535i
2008 VW GTI
      08-20-2008, 07:18 PM   #3
rockmed
Drives: none
1. An iPOD
2. USB stick
Thanks for shedding some light. Where in the car would I be able to find the "dual" cable? What would be the difference between using the "dual" special cable and just connecting an iPod with standard Apple USB cable?
      08-20-2008, 07:41 PM   #4
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
The AUX/USB connections are in the center console. The cable would be in there. They may provide other cables, extensions, etc.
I know there is more than one cable. But the Y is all you need for an iPOD and USB stick from what I have heard.
2011 535i
2008 VW GTI
      08-20-2008, 07:55 PM   #5
JeffCBH
Drives: 2008 BMW X6 50i
When I got my X6, the cable was in the owner's manual leather packet...you have to hook up the wide connector to the iPod and the Y output of that into the USB plug and the stereo mini plug audio input...2 connections on one end, and the other wide connector into your iPod...works perfectly...an amazing integration of the iPod...best I have seen.
On my other cars, the iPod integration has been laughable...a complete waste of time.
BMW has nailed it.
Jeff
      08-20-2008, 09:19 PM   #6
ggatlin
Drives: BMX X6
On my X6 5.0i, for some reason I did not get a cable. What I am doing is using the USB Cable that came with my Ipod Classic 80GB which I just bought last week to connect to the car (So its a new model of Ipod Classic). The Ipod works but I do not get all my songs listed on the car. Could it be because I am using the Ipod USB cable that came with the Ipod, and not the one that came with the car? I get some songs from an artist, but not all.
Please advise.
George
      08-20-2008, 09:55 PM   #7
shenard
Drives: '09 X6 50i AW
2009 BMW X6 50i  [0.00]
Please advise.
George
That is probably the case because I do not have that problem with mine and I am using the supplied cable
      08-20-2008, 10:52 PM   #8
ggatlin
Drives: BMX X6
Shepard,
You are right, I was reading in other websites, and indeed the Ipod will work completely without the special BMW USB Y Cable. "For full integration, you need the BMW supplied Y cable that plugs into the USB and Aux in at the same time..."
Does anybody know where can I buy this cable in the U.S.A? My dealer in El Salvador does not have one.
Thanks
George
      08-21-2008, 08:32 AM   #9
xDrive50i
xDrive50i's Avatar
Drives: '09 750i individual
Please advise.
George
Only BMW USA includes the Y cable with the 6FL option (that is also the reason why the 6FL option is more expensive in the USA than in other countries!).
The Y cable is not JUST a cable that splits the audio and data cables from a wide ipod docking style connector into a USB and audio connector. There is a small box in between the docking connector and the USB and audio connector. This box contains some electronic to convert the USB data stream into serial data to control the ipod/iphone. Essentially this cable translates the commands from the head unit into serial data to control the ipod/iphone. The ipod/iphone does the actual decoding of the song (e.g. MP3) and outputs the audio via the docking connector in analog form. The Y cable presents this signal at the audio output cable that you have to plug into the aux input in the center console.
If you use a USB stick, any other MP3 capable player or ipod/iphone connected to the head unit via a REGULAR USB cable, the head unit does the actual decoding of the data (e.g. MP3) and hence there is no analog connection required. The difference for the ipod/iphone is that to the head unit, it simply looks just like any other storage medium (rather than an actual ipod/iphone).
You will notice that the integration of the ipod/iphone will look quite different when you use the Y cable compared to a simple USB cable.
Hope this helps you.
2009 750i individual | Citrin Black Metallic | Platinum Merino Extended Leather | BMW Individual Composition Package (includes Sport Package) | Dynamic Handling Package | Multimedia Package | Technology Package | Executive Package
http://www.7post.com/forums/showthread.php?t=234432
      08-21-2008, 08:32 AM   #10
shenard
Shepard,
Thanks
George
They should be able to order one for you. If not, I would think you could call a US dealer and have them order one and ship to you.
      08-21-2008, 08:36 AM   #11
xDrive50i
xDrive50i's Avatar
If you do, make sure you get the latest version. BMW went through quite a few different revisions on that Y cable. The latest one is quite a bit smaller than the older ones!
      08-21-2008, 09:43 AM   #12
ggatlin
Drives: BMX X6
Thanks guys, am definetely clear on Y-Cable now, and will order one with a U.S. Dealer.
George
      08-21-2008, 04:03 PM   #13
rockmed
Drives: none
I tried the iPod nano, iPod and iPhone via the regular Apple USB cable but nothing worked. Has anyone tried, and if so, how long does it take before iDrive recognizes it? Thanks!
      08-21-2008, 04:05 PM   #14
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Use BMW's cable. It si not a standard USB.
Remember the iDrive controls the iPOD as well. This is not one way communication.
2011 535i
2008 VW GTI
      08-21-2008, 05:30 PM   #15
rockmed
Drives: none
True, but it will be a at least 1 week before I get the Y cable. I need an interim solution. Thanks.
      08-21-2008, 05:31 PM   #16
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Just use the Din8/DIN8 audio jack. you can't control the iPOD and it won't sound as good but it is easy and works.
2011 535i
2008 VW GTI
      08-21-2008, 05:44 PM   #17
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Any USB cable and a Memory stick, all the functions work perfect.
      09-02-2008, 01:35 PM   #18
rockmed
Drives: none
Just received the Y-Cable today, plugged it in and the USB Integration worked perfectly with the iPod. For those of you who have USB Integration but are missing the Y-Cable just Google 61120440796 and you should see a list of online BMW parts stores which you can order from.
      09-02-2008, 02:32 PM   #19
MeEmZ
Doctor in the making
MeEmZ's Avatar
Saudi Arabia
46
Drives: 08 X6 35i
I haven't read through all the posts but when I hook up my ipod to the car I use the white cable that came with the ipod for apple and it works just fine no problems what so ever
but i have tried a usb flash disc (a kingstone 2gb) and it wasn't working at all the car didn't discover it
08 X6 35i
09 X5 3.0is //M
      01-06-2010, 06:43 AM   #20
x5cabrio
Drives: bmw x6
Hello, la mia x6 3.5 D futura ha solo la presa aux in. Come faccio a mettere la presa usb ? dove posso trovare un kit post montaggio ?
Grazie. Fabrizio
fa.bo@libero.it
      03-02-2015, 06:16 AM   #21
CONVOY
no usb interface
when i got my bmw x6 30d i noticed it didn't have a usb port only AUX port,is there way to update the software of the iDrive?
      11-12-2019, 08:22 PM   #22
BLK-EDTIONX6
Drives: 2010 X6 BLK EDITION
2010 BMW X6  [0.00]
I tried a flash drive also and it didn't work as well but after debugging my samsung N9 it was able to connect through the interface and it plays music from my phone. However, i can copy music from my phone to the idrive. Can anyone shed some light?
