BMW 3-Series (E90 E92) Forum
m3 strut mount
08-08-2019, 10:06 AM | #2 |
Rep 249
My wallet felt lighter by a couple hundred dollars..
08-08-2019, 05:34 PM | #4 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
But can you really see it once its installed
Common sense is a flower that does not bloom in everyone's garden
08-08-2019, 06:10 PM | #5 |
Rep 2,285
If you have adjustable struts from the top its easier.
I had to cut down the bolts and dermal the plastic cowl to make it fit correctly. I did not feel a difference. But then again I did not feel a big difference when I installed the m3 front sway bar or the front arms. |
08-08-2019, 06:57 PM | #6 | |
Rep 996
08-08-2019, 07:30 PM | #8 |
Rep 1,105
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
I put a strut brace on my e91. Felt the improvement immediately over even the lightest of imperfections in pavement. It had 125k miles, so it was loose compared to my lower mileage e90.
08-08-2019, 08:46 PM | #9 |
Rep 996
08-13-2019, 09:01 AM | #10 |
Rep 1,105
08-13-2019, 09:50 AM | #11 | |
Rep 1,893
A ridiculously expensive waste of money. It is not going to make your 335 handle like an M3 I can guarantee you. If you want your car to handle like an M3, you will have to install ALL of the MANY suspension changes. Simply one or two component is unwise - sway bars, springs, dampers, suspension bushings, tires, wheels and ride height all work together in a coordinated, intentional manner. Furthermore, it is important to consider the end use - what is good for autocross is usually not good for other track events and usually not optimal for street - actually, what is good for streets in one location may not be very good for streets in another. End of rant Last edited by dpaul; 08-13-2019 at 09:58 AM.. |
08-13-2019, 11:41 PM | #12 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Does your username indicate any connection with the company?
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
08-13-2019, 11:43 PM | #13 |
945
Rep 1,507
I would say not worth the money, that would be a very late build modification for me. So many other things to put money into that would have a much more significant improvement.
