06-05-2019, 11:54 AM | #1 |
Rep 1,027
Valve Issue - VSC-2
I'm facing a weird issue with the VSC-2 where it stops working after I drive the car
Symptoms are as follows: - On cold engine and when starting car up, I'm able to open/close the valves through remote - After driving 5-10 minutes or more, remote valve open/closed functionality stops working. Valves don't move and stay in whatever position selected on car start up - When switching car off after a drive and turning it back on, valves only open/close on the left side (same place as where VSC-2 Box is) - When starting the car in OEM Mode (ON=Valves Open/OFF=OEM Mode), after having driven the car, only left valve opens on Sport+ start-up I initially thought it might have been a heat related issue as the aluminium wrapped cable wasn't routed under the heat shield but zip tied to the chassis. However, after putting the car on ramps and touching the cables, there wasn't enough heat to believe it may have been a problem. Car is European, so with OPF and is running a Remus exhaust with link pipes up to the OPF. I've ordered another VSC-2 unit, thinking perhaps I got a faulty unit but I fear there might be another issue at hand. Assuming it's not the VSC-2 unit being faulty, what could the issue be? Is BMW ECU interfering with the VSC-2 as the result of OPF sensor? Did the notorious BMW software update in March that patched OBD flashing also tampered with aftermarket valve control modules? Or perhaps are the Remus exhaust valves faulty and with heat they aren't able to move? Wondering if anyone else has had a similar issue and/or knows a solution? Cheers! Last edited by Dav3; 06-05-2019 at 12:29 PM.. |
06-05-2019, 03:40 PM | #2 |
Rep 1,027
Perhaps no one has any clue what might help
But, can anyone confirm exhaust behaviour for me? I've reconnected one of the valves with the OEM bmw harness, ditching the VS2 harness My exhaust behaviour on start up is: - On efficient, valve stays closed, press the accelerator in neutral, valve stays closed - On Sport Plus, valve stays closed, press the accelerator in neutral, valve opens (so opens but not on start up) Can anyone confirm this? |
06-05-2019, 04:14 PM | #3 | |
Rep 408
Sounds accurate.. I can hear my valves open as I press the gas pedal in sport + when my car is warmed up. Efficient doesn't seem to open the valves as well.
Dav3948.50 |
06-05-2019, 04:50 PM | #4 | |
Rep 1,027
Experimented a bit and found out that with the following sequence you do a cold start up with valves open 1. Press start without foot on brake 2. Select Sport Plus 3. Press accelerator (engine still off) 4. Then turn engine on 5. Start up with valves open So yeah, based on this, valves should be fine at least on start up I guess. |
06-07-2019, 01:08 PM | #5 |
Rep 8,970
Yes but valves shut / open once moving according to speed / load etc in eco and sport.
Don't assume that if they are open when stationary they will stay that way. |
06-07-2019, 03:07 PM | #6 | |
Rep 1,027
With VSC-2 after warmed up engine either one or none of the valves moved With valves opening on warm engine with OEM actuator, pretty much proves its probably not a valve issue Let's see next week with the new VSC-2 unit if my old unit was faulty or it's something with the BMW Ecu |
