01-28-2019, 07:52 PM | #1 |
N54 to N55
66
Rep 308
Bootmod3 Stage2 AMAZING
So got my catless dp installed and in turn right away upgraded to the ots Stage 2 map. All I can say is the car is whole other animal, in the best way possible. 1st to 2nd gear shift soo much smoother! (6mt)
Did have a question if anybody has messed with the map config, more specifically the boost reduction by gear %? In 2nd gear looks like Im at about 16-18lbs of boost, traction is not horrible but I would definitely be at a disadvantage doing a 2nd gear pull. I was thinking maybe 10-15% reduction might help. But then again blowing out the tires is pretty fun lol! |
01-28-2019, 08:31 PM | #2 | |
Rep 290
01-28-2019, 10:38 PM | #3 |
Rep 148
If you have an 8 speed Automatic your gonna need a TCU flash!
01-29-2019, 11:24 AM | #5 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
01-29-2019, 11:43 AM | #6 | ||
Rep 643
M235i rwd 6mt
01-29-2019, 12:56 PM | #9 | |
N54 to N55
66
Rep 308
Also for the e30 map do you always have to have a ethanol blend in or what happens if you just fill 93 octane a couple times? Are you just fbo running e30? Log is 2nd gear WOT around 4500 rpm. Temp outside about 52F, brand new ngk plugs as well. Last edited by este; 01-29-2019 at 01:19 PM.. |
01-30-2019, 11:08 PM | #11 | ||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
So e30 maps are for only running e30 fuel. If u throw in 93 the higher cylinder pressures are more likely to cause knock (predetination) Are u using a wifi OBDII agent? Makes changing maps at the gas station very easy and fast. If u don't there's a REALLY good diy on how to make the same one bm3 sells. Diy cost is like $60 vs bm3's $300
Quiet M235i
Dylan861330.00 |
01-31-2019, 03:27 PM | #13 | |
N54 to N55
66
Rep 308
02-01-2019, 06:03 PM | #14 | |
Joint Chiefs of Staff
24332
Rep 191,093
este66.00 |
03-05-2019, 01:33 PM | #16 |
N54 to N55
66
Rep 308
03-06-2019, 08:42 AM | #17 |
Rep 151
Thanks. I have the Auto and just got the BM3, so I was making sure that I didn't need something else.
03-06-2019, 10:55 AM | #18 |
Rep 218
You don't, don't let anyone else tell (sell...) you otherwise. I've been running BM3 stage2 for a while now and with their latest update, version 6.3 I believe, the jerkiness/hesitancy that my ZF8 had is now gone. I'm really enjoying it!
03-06-2019, 11:42 AM | #19 | |
Rep 716
Drives: F90 M5
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
03-06-2019, 02:03 PM | #20 |
Rep 115
Give us a review of how it changed over the OTS maps.
2014 M235i
03-06-2019, 08:44 PM | #21 |
Rep 716
Drives: F90 M5
First off the OTS maps are amazing! But a custom map will really utilize all the parameters of your specific car and the fuel used. My experience with CaryTheLabelGuy custom map literally left me with my jaw dropped and a holy shit every time i get on the gas. Just as smooth as the OTS but just a good amount faster, I havent had the chance to put it on the dyno yet, but it feels like a good bump of about 25-30whp and about 50ish wtq.
So far it has been extremely reliable without even a hiccup. as far as customer service goes Cary is the best! quick response times and he really works with you to make the car perfect for exactly what you want and he has the ability to control certain things that you may or may not want (such as flames). For me it took about 3 revisions of the map to get it dialed in just right. and another 3 to get the flames to be perfectly matched to my liking Sorry if thats not exactly the review you were looking for. But theres my short review.
03-07-2019, 08:08 AM | #22 | |
N54 to N55
66
Rep 308
Since you mentioned flames, a quick video wouldn't hurt lol! |
