BMW 3-Series (E90 E92) Forum
DIY info #2 - parking brake handle...
03-12-2006, 01:40 PM | #2 |
Rep 3,011
oh good luck... search this topic for yerself, but my understanding is that the oem brake handle is glued on and very difficult to remove.
"Teach the ignorant. Ignore the stupid."
03-13-2006, 04:25 PM | #3 | |
Rep 16,628
03-13-2006, 11:39 PM | #4 |
Rep 3,011
really? I'll have to gove it a try.
Hey longtran... is there anything you havent fiddled with in your car? Yerself included?
03-19-2006, 05:51 PM | #5 |
Rep 946
Drives: BMW Fanatic
Garage List 2013 Fiat Abarth [0.00]
1993 Honda Civic EG ... [0.00] 2009 Suzuki LTR 450 [0.00] 2008 Acura MDX [0.00] 2001 Z3 M Coupe S54 [0.00] 1988 E30 M3 [0.00] |
Yup..Longtran is right..The factory e-brake handle is super easy to remove..Just yank on it hard and it'll pull right out..I replaced mine a while ago with the ACS handle...
1988 E30 M3 Diamantschwartz/Black |
03-23-2006, 04:44 PM | #6 |
Rep 14
The leather cover is definitely glued to the handle! I had to take a little screw driver and pry the glued leather off the handle then give it a good jerk and off it came! When I Installed the new one (Poplar) I can see a gap because I did not glue the leather sleeve to it. Any suggestions on glue choice?
03-23-2006, 04:46 PM | #7 | |
Rep 946
Drives: BMW Fanatic
03-23-2006, 10:51 PM | #10 | |
Rep 121
Or if that's too ghetto, go to an arts & crafts shop & find some leather or naugahide or suede of the right color and glue a thin strip in the gap.
2006 330i | Black Sapphire Metallic | Black Dakota Leather | 6SP MT | ZPP | ZSP | ZCW | Sirius
03-26-2006, 08:20 AM | #12 | |
Rep 946
Drives: BMW Fanatic
03-26-2006, 06:13 PM | #13 |
Rep 14
Shadye90, Thanks! After carefully feeling around the upper portion of the sleeve, I could feel a metal or plastic band which I worked into the groove of the handle! My problem was, I was doing this whlie the brake was off (down position) when I pulled it up I had plenty of slack to work the ring on to the handle!!
All is well! Thanks Again! |
03-26-2006, 06:53 PM | #14 | |
Rep 946
Drives: BMW Fanatic
11-25-2006, 06:51 PM | #16 |
Rep 713
Drives: '06 E90 - '04 E85 - '16 F15d
I changed over to the Pearlescent chrome E-Brake handle. The leather boot is held onto the handle with a nylon tie wrap on the inside. Once you turn the leather inside out you can easliy clip off the old tie, pull the old handle off, and replace with the new handle (securing the leather with a new tie wrap). The whole process took about 5 minutes.
Finished product..... More pictures of final look at http://www.e90post.com/forums/showpo...&postcount=312
