OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED** |
01-10-2018, 02:25 PM | #1 |
Joint Chiefs of Staff
24328
Rep 191,065
Can be done from home with the use of the Simon Cable. You still have the option to send your ECU to Active direct if you do not wish to purchase the Simon Cable. Active Autowerke offers unparalleled performance software. Through careful remapping of the factory BMW DME tables, various elements such as ignition timing, fuel delivery, and part throttles are reworked to create performance gains. The Active Autowerke upgraded software is designed to operate with gasoline that has an average octane rating with full emissions to create a clean burning combustion with good AFR’s all within factory specifications. Available Options:
Performance Specs:
This is an OBD flash tune, no need to remove the ECU Attention Florida Customers: If you are local to Active Autowerke (9940 SW 168th Terrace, Miami, FL 33157), there is no need to purchase the Simon Cable. All you need to do is purchase the map from Extreme Power House and drive down to AA for a free install. ***EDIT*** Dyno from a customer. Car mods: Catless Downpipe Note: Car is using stock intercooler. Temps were going over 180 degrees on high RPM which caused the ECU to cut power. A car with a quality aftermarket intercooler will make even more power on high RPM. Same customer, same day same car with Active A piggy. Im posting this A8 dyno to showcase the power delivery difference between the Active flash and their piggy. F30 335 Stock (With Downpipe) vs Active Autowerke OBD Flash Stage 2 +65whp / +109wtq
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 02-23-2018 at 11:56 AM.. |
01-10-2018, 02:34 PM | #2 |
Rep 5,381
Man, it's all coming out of the wood work now. Exciting times.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
01-12-2018, 03:22 PM | #4 |
Rep 1,753
Starting to feel like a lot of "me too" going on now. I'm gonna wait to see how it all shakes out.
01-12-2018, 03:31 PM | #5 | |
24328
Rep 191,065
They have also been flashing the new chassis for more than a year but never released the software until an OBD solution was available. Their maps are the same (tested on a large number of FL BMWs), the only thing that changed is the way you upload it.
01-12-2018, 03:38 PM | #6 | |
Rep 1,753
01-12-2018, 04:13 PM | #7 |
Rep 525
In theory, they should all have access to the same features/parameters since they're all using OBDII. The difference would only really be in the tune or the mapping side of the engine parameters that affect how the car runs. Well, that and the UI, I guess.
01-25-2018, 11:09 AM | #9 |
24328
Rep 191,065
Its already available, i will send you a pm
01-25-2018, 12:24 PM | #10 |
Rep 647
01-25-2018, 01:38 PM | #12 |
24328
Rep 191,065
Active Autowerke are offering free dyno sessions and install for all volunteers
We should have it in 1-2 weeks
01-25-2018, 02:07 PM | #14 |
24328
Rep 191,065
All OBD flash will trip the counter... You can always remove it in the future send it to Active and they will take care of that for you
01-25-2018, 02:28 PM | #15 |
Rep 525
I can see them resetting the counter back to the default value since that should be a known value, but what about the time stamps? How would they know what the original time stamp was before it was overwritten with the new time stamp at the time of OBD flash?
01-25-2018, 02:33 PM | #16 | |
24328
Rep 191,065
That being said, it all does not matter. If BMW wanted to really dig and know if you had a tune, they will know with or without the counter register.
01-26-2018, 01:25 PM | #17 |
24328
Rep 191,065
01-26-2018, 06:58 PM | #19 |
24328
Rep 191,065
Whats more impressive is how smooth the Active flash power delivery is
01-26-2018, 07:07 PM | #21 |
Rep 555
That torque though.... they might as well sell rear wheels and fender flares with it, that is going to roast the stock 245s
Taskmaster2465.00 |
02-02-2018, 03:11 AM | #22 |
Rep 26
I found this in AA website
" Your ECU must be taken to an approved Active Autowerke F3X dealer for the initial flash, or it must be shipped to Active Autowerke before you are able to load our maps with a Simon 3 cable from your home." Do we need to send our DME for initial flash? Please explain Mike. |
