10-08-2017, 06:48 PM | #1 |
Rep 148
Drives: F30 335i sport line
Garage List 2012 BMW F30 335i S ... [0.00]
2006 BMW 330xi [0.00] 2007 Toyota FJ Cruiser [0.00] 2003 MINI cooper S [0.00] |
Sudden failure of my bimmertech rear camera
So I purchased the Bimmertech rear view camera and installed it a year ago and can't go on enough about how much I loved it. It was working today until I parked my car and later went out to run an errand. This time when I went into reverse the screen went black (which it usually did for a small fraction of a second before the camera view came on) but this time it only displayed the backup lines superimposed on my normal screen with no camera view. This has never happened before. I tried to to a factory reset through the units menu and remote but this still didn't fix the issue.
Has anyone had this issue before? If so, how did you fix it? Last edited by messygarageBMW; 10-08-2017 at 07:00 PM.. Reason: add pic |
10-08-2017, 07:01 PM | #2 | |
391
Rep 449
10-08-2017, 07:05 PM | #3 |
Rep 148
It is the MMI and I didn't take the dash apart yet to check. I wanted to see if there was some other ideas before I tore it out and tried to reset everything back up. I wasn't in there doing anything else so the connections coming out doesn't seem likely as it was just working less than an hour before.
Another annoying aspect is after doing the factory reset it is now looking like it is only on part of the screen now and the backup sensor blocks are in there. I forgot how to reset it to full screen and take the backup sensors blocks off which is how it was for the last 1 year +. |
10-08-2017, 07:06 PM | #4 |
Rep 148
10-08-2017, 07:19 PM | #5 | |
391
Rep 449
Even though you already did a reset, I would go in your car and hold "Option" on the iDrive screen for about 10 seconds. This is another way to do a hard reset. You'll know it worked when you see the idrive display briefly turn off and back on again. Then, test it out... If it's still not working right, put the car in reverse and try to press the iDrive controller to the 6 o'clock position for about 3-5 seconds. This will change from Full Screen to Partial Screen. If you let go and hold it down for another 3-5 seconds, it will go from Partial to Nothing and if you hold it again.. you guessed it.. Nothing to Full Screen. As for the Red Squares, put the car in reverse (the reason I keep saying put the car in reverse is because you have to be on a "BimmerTech over-ride screen to access the menu") Next... hold the "back" button on your iDrive controller for about 3-5 seconds. Look for "Radar Enable" and turn it off. That should get rid of the red squares. If you still have trouble, you can reply on here (sometimes I don't get notifications) or email me at bryan@kiesmotorsports.com and I can try to help you trouble shoot it. Worst case, I can connect you with BimmerTech support. Bryan |
MAKH 588.50 |
10-08-2017, 07:33 PM | #6 |
391
Rep 449
Yea, I?ve had it show lines with a disconnected camera before. Normally a black screen with dynamic lines
10-08-2017, 08:20 PM | #7 | |
Rep 148
This worked. Camera is back and working. Full screen is restored and now to follow your suggestion for the radar enable issue and all will be right with the world again. Thanks for your help! Denny |
10-09-2017, 04:20 AM | #8 | ||
391
Rep 449
Bryan |
