05-01-2017, 08:43 AM | #1 |
Rep 58
Drives: X5i M-sport,E24 M635i,E34 535i
Comfort access not working on driver side
Comfort access is not working on the driver side the other doors are working fine. On the driver side door handle I can feel that the handle is a little warmer than the rest of the doors. Can the handle be removed without removing the door panel. Would like to buy a handle off Ebay and replace the parts to avoid having to paint the handle.
Thanks |
05-01-2017, 08:45 AM | #2 | |
Rep 1,714
They ended up replacing two door handles
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
05-01-2017, 09:11 AM | #3 | ||
Rep 1,695
05-01-2017, 09:17 AM | #4 |
Rep 1,714
I agreed, they definitely didn't know what they were doing and the vehicle was there for 2 weeks. They covered everything 100%, I even got a goodwill fuel filter replacement out of it.
05-01-2017, 10:05 AM | #5 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
I swapped the rear handle for the driver door handle.
So now my driver door CA works but rear driver side door does not. |
05-01-2017, 11:28 AM | #6 |
Rep 397
These CA door handles are garbage ... I've had 3 out of 4 fail on my truck already and no longer have CA handles on the rear doors. :/
They are very expensive to replace out of warranty - about $250/piece color matched to your truck. My advice is to unplug any that are hot/not working properly since they drain the battery and cause "High battery Drain" errors - No need to replace with another handle if your not up for spending that much on a door handle ... |
05-01-2017, 01:02 PM | #7 | |
Rep 906
05-01-2017, 01:14 PM | #8 | |
Rep 397
Attempted to take it apart starting with the notch in the rear but it didn't go anywhere, took the small squarish notch off and revealed nothing that would point to it being repairable. Handle seems to be glued together and not meant to be disassembled ... at least easily or where it would go back together properly. |
05-10-2020, 03:03 AM | #9 |
Rep 1
05-10-2020, 07:59 AM | #10 |
Rep 398
I recently swapped out my non working passenger handle with one I bought off eBay for around $40, found a good deal so i pulled the trigger. Works perfectly and was easy to install.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
