BMW 3-Series (E90 E92) Forum
What is this brake wire?
12-18-2016, 05:31 PM | #1 |
Rep 342
Drives: 2007 335i E92
I was swapping tires for the winter when I found this wire just dangling. It is on the front driver side. The front passenger side doesn't have this wire or at least I cant find it. I have no idea what it is or where it plugs into. Any help would be great, thanks!
2011 X5 35d Daily - DUDMD Stage 2 and Deleted
2007 E92 335i - | Wedge Custom Tune | VRSF DP's| VRSF Race Intercooler | PE Mod Exhaust | Stage 3 LPFP | MMP Port Injection | VTT Stage 2+ Turbos | DKM Twin Disc | E85 | |
12-18-2016, 05:35 PM | #2 |
Rep 5,367
if its not broken you just plug it back into the brake pad.
http://cdn4.pelicanparts.com/BMW/tec..._Pads/pic3.jpg
You can follow my builds on IG: Tee212 |
12-18-2016, 07:03 PM | #4 |
Rep 342
Thanks, this must have been broken for a while because I have had the brake light on my dash for the last year. Oh well, il just buy a new sensor. Thanks again!
12-18-2016, 09:52 PM | #6 |
Rep 342
Plug it back in, lol. It's so destroyed it looks like a hunk of round plastic. Thanks for the info tho, I'll buy a new one.
12-19-2016, 02:17 PM | #7 |
Rep 342
I hate these things, I'm capable of checking my pads on a regular basis. Which is why I cut the wire and spliced the two ends together, no more brake light for this guy
2007 E90 335xi | 400WHP // 430WTQ
12-19-2016, 03:13 PM | #8 |
Rep 342
So you cut the end off and just tape the two wires together? Sounds good enough to me, il do this until i get a new sensor.
pysical129.00 |
12-19-2016, 03:46 PM | #9 |
Rep 342
Yepp. Just make sure you cut them so that you can eventually replace the sensor if you want to. But yea just strip both end, twist them together, and tape it up. Be sure to unplug the sensor before doing this, it should be low voltage but better safe than sorry.
12-19-2016, 04:59 PM | #10 |
Rep 342
Just did it. Brake light didnt go off. Il have to drive it around then it will go off hopefully. Thanks!
12-19-2016, 08:56 PM | #11 |
Rep 2,109
You need to reset it for it to go off, from CBS. Make sure you only reset the front brakes. If you try to reset an already half way worn brake sensor, which your rear sensor most probably is, it will set off the light.
