12-03-2016, 05:30 PM | #2 | |
Rep 2,214
D
12-05-2016, 03:41 PM | #3 |
Joint Chiefs of Staff
24331
Rep 191,093
Jb4 is the way to go ... We offer 14 days money back guarantee if you would like to give it a try
12-05-2016, 10:34 PM | #4 | |
The Schwab
474
Rep 1,605
Drives: 2020 AW M340xi
OP look into doing a flash tune and do it right from the start. PM me if you want more info. |
12-06-2016, 01:13 PM | #5 | |
24331
Rep 191,093
Did you bother checking our website before posting? We offer Burger Tuning, Afe, Enzo, Active Autowerke tunes and soon BM3 Not sure how many more alternatives you need. I push it because it is the most complete tune at the lowest price. Why would i pay more to get less?
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 12-06-2016 at 01:38 PM.. |
12-06-2016, 01:37 PM | #6 | |
Bright Sky
1165
Rep 922
Drives: BMW M235i (8AT)
It offers: - Logging - On-the-fly map changes (bad weather? stock map! Trackday? race map!) - Live readout of parameters - Direct EWG boost control - Meth kit ready - Bolt-on ready - Excellent BT options (log collection, map changes, firmware updates) I don't think any of the others boxes offer this and a flash tune is less flexible. That's not me saying that flash is a bad option, definitely not! But if you want a quick, affordable solution that offers future mod compatibility a JB4 is a very nice device. Hell, it can even be used with a flash tune so you can have both if you so desire.
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
mike@x-ph.com24330.50 |
12-06-2016, 02:12 PM | #7 |
Rep 2,214
^^ Exactly. Not a case of good or bad, but I feel it's the best starting point. This said, ESPECIALLY WHILE UNDER WARRANTY. Last thing you need is a blown "x" and a flash tune which can't be removed.
12-06-2016, 05:38 PM | #8 |
Rep 183
so if i put my JB4 at map zero the dealer won't be able to tell i have a tune on?
also i saw it at 549$ on the official website is there somewhere i can get it cheaper what is the max torque and hp it gives on a stock car? also some guy suggested me JB+ but for 150$ i rather get the real thing !! |
12-06-2016, 05:44 PM | #9 | |
24331
Rep 191,093
We offer it for much cheaper than that, im not allowed to post links on here Here is a dyno
BodegaBay27.00 |
12-06-2016, 07:13 PM | #10 |
Rep 183
ok then send me a PM message of the link of ur JB4 for N55 2016 235i
also i wanna know for JB4 on stock at what map max would u go if u were me? i heard map2 is max is that right? |
12-06-2016, 07:14 PM | #11 | |
24331
Rep 191,093
On a stock car, use map 1 Map 2 is used if you have downpipe
12-06-2016, 08:11 PM | #13 | |
24331
Rep 191,093
+ phone support + forum support it is not all about money
12-06-2016, 10:00 PM | #14 |
Rep 31
I went with Dinan due to the warranty and not having the hassle of having to uninstall it if I go in for service when BMW is footing the bill. I have read great things about the JB4 and would have gone that way if my car wasn't leased. Maybe if I buy this one after my lease I'll go with a JB4 ... seems to be much more flexible with mods and options.
12-07-2016, 10:53 AM | #15 | |||
The Schwab
474
Rep 1,605
BM3 is an absolute gamechanger, which would give you all the ancillary features of the JB4, but with the much more powerful direct DME flash. Quote:
Blown x -> revert the DME to stock -> take to dealer to fix under warranty. Flash tunes are only detectable by removing the DME and seeing if its tampered with, or by doing OBD flashes (which throws a tamper code). However, the tamper code solution is being worked on as we speak with bootmod 3, and will alleviate any and all concerns around reverting to stock. |
Dylan861330.00 |
12-07-2016, 10:56 AM | #16 | |
24331
Rep 191,093
Enzo is not a good flash? We also offer BM3
12-07-2016, 11:00 AM | #17 | |
The Schwab
474
Rep 1,605
Do you plan on staying just stock and doing a tune? Doing a downpipe in the future? Going FBO + tune? Utilizing meth or ethanol? These will all factor into your decision around a tune. If you want to start with the tune and upgrade as you go along, the JB4 would probably make the most sense. The JB4 can support your future mods until you decide you want to make actual power and then I would suggest getting a custom flash tune for your mods/power goals. If you plan on only staying stock, I would just opt for a Stage 1 tune. You can take them on and off in minutes, and they are cheap (BMS Stage 1). They will net you about the same gain as the JB4 since you will need to run Map 1 anyway. |
BodegaBay27.00 |
12-07-2016, 11:05 AM | #18 | |
The Schwab
474
Rep 1,605
There have been countless horror stories around Enzo. I won't get into it here, but you can do some searching and read up on it yourself. I personally know multiple cases of people that have gone with Enzo and its been an absolute disaster. BM3 is great, still a bit buggy currently, and the tamper code protection hasn't been fully flushed out. I plan on moving to BM3 in the spring, and having ACF Performance create multiple flashes to select from. Best of all worlds. |
12-07-2016, 11:56 AM | #19 | |
Rep 3,256
http://f80.bimmerpost.com/forums/sho....php?t=1327330 |
Anthony235715.00 |
12-07-2016, 12:07 PM | #20 | ||
Rep 1,753
12-07-2016, 04:03 PM | #21 | |
The Schwab
474
Rep 1,605
I plan on going BM3 come spring. |
12-07-2016, 04:12 PM | #22 | |
The Schwab
474
Rep 1,605
Regardless, my tuner is local so I can always flash back to stock before service (if ever), and my SA is unbelievably cool with mods. Not overly concerned here. |
