TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > E92 keyhole cover
      04-09-2008, 04:11 PM   #1
Appropriate
Appropriate's Avatar
Drives: 2008 BMW E92 335xi
2008 E92 335xi  [0.00]
E92 keyhole cover
Anyone done this? How exactly do you get the old part off... the sellers of these say you just need a screwdriver, but I'd like to hear from someone who's actually done it.
http://www.jlevistreetwerks.com/prod...roducts_id=683
      05-08-2008, 01:47 PM   #2
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
385
Drives: '11 F25
'11 BMW F25  [0.00]
i would like to know too! the PDF that comes with keyhole covers from Bimmian shows that there is an oval rubber plug that needs to be removed from the door to access the screw, however, my E92 does not have such oval plug in the door. want to know before i spend $$
      05-08-2008, 02:32 PM   #3
ak47firepower
ak47firepower's Avatar
Drives: Sapphire Black 335i Cab
2008 335i E93  [0.00]
To access the screw, you need to pull the rubber flap up to expose it. A rubber grommet on the rubber flap covers the hole. Taking the screw out is tricky, as it comes out at an angle to the keylock mechanism. You don't need to actually take out the screw. Just loosen it all the way. You will need to pull and wiggle on the lock assembly from the outside quite hard to pull out the entire lock mechanism. Once you got the assembly out, make sure you don't pull on the door handles too hard or close the door. If you pull on the door handles too hard they may disengage and then it might be tricky to put it back. You can now decide whether you want to put the lock cylinder into your new keyhole cover or leave it without one.
If you want to remove the lock cylinder there are 2 clips that keep it in place. Use a flathead screw driver to pull them up to get the cylinder out. Put the lock cylinder into the new keyhole cover and put the entire assembly back in. Remember to align the screw at an angle to the threads on the keyhole cover and screw in. Replace the rubber grommet on the flap into the screw hole and you're done.
It should take about 15-20 minutes or so. Good luck!
      05-08-2008, 02:42 PM   #4
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
385
Drives: '11 F25
'11 BMW F25  [0.00]
got it! thank you!
      05-08-2008, 03:23 PM   #5
Appropriate
I've ordered mine, but jsut haven't received it yet... we'll see...
      05-08-2008, 04:57 PM   #6
rdsport323
Drives: 335i
i wonder if this will also remove the blueish tint light that lights up when you unlock the car or open your doors. I think its pretty nice to have that light there even though you don't use the keyhole much..
      05-08-2008, 05:50 PM   #7
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
385
Drives: '11 F25
'11 BMW F25  [0.00]
i just checked on door, and there is a plastic "window", not just a bare cut-out.
from what i understand they come with a cut-out for the light, but im not sure if there is a window or not
      05-08-2008, 06:48 PM   #8
ak47firepower
Its a cut out just like the original key cover, so you still get your courtesy lights.
      05-26-2008, 06:18 PM   #9
amdave
Drives: '08 335i Coupe: AW/CR/Loaded
what happens when keyless entry stops working?
2008 BMW 335i Coupe | Alpine White | Coral Red // WRECKED!
      05-27-2008, 12:00 AM   #10
E92Vancouver
E92Vancouver's Avatar
33
Drives: 2000 E46 & 2007 E92 328
You go in through the trunk.
DIY without pics SUCK!!!!!
      05-27-2008, 12:02 AM   #11
NPDAN
NPDAN's Avatar
95
Drives: AW DCT M3
2008 E92 M3  [8.00]
07' E92 335i  [0.00]
I've got it. It was an easy mod...
      05-29-2008, 03:05 PM   #12
Appropriate
+1
      05-29-2008, 08:47 PM   #13
BE.EM.VU.
BE.EM.VU.'s Avatar
Poland
9
Drives: Sapphire Black 08 E90 335i 6sp
I keep a spare battery for the key fob in the trunk.
" Sometimes it's good to be me..."
      09-18-2008, 02:42 PM   #14
BaLLzZz
BaLLzZz's Avatar
Drives: e92 335i
what kind of screw is that i just took a look at it?
Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius and a lot of courage to move in the opposite direction. - Albert Einstein
01 e46 m54 - Current : 14 f10 n26 - Boring & Gone : 15 f30 n26 - Current : 08 e92 n54 - Gone & Missed!!!
      09-18-2008, 06:03 PM   #15
wrh3
Car Guy
wrh3's Avatar
31
Drives: 2005 MCS, 2013 Corvette 427
Here is my DIY:
Bimmian Keyhole cover purchased from Mod Bargains- added security and enhanced aesthetics. The keyhole cover comes painted to match your paint code. To remove the lock cylinder, the rubber seal at the corner of the door has two rubber nubs that are press fit, can be removed by carefully pulling out until the bolt hole for the lock cylinder is accessible. A 4mm HEX wrench is used to loosen/remove the HEX bolt and the lock cylinder can be pulled out. Installation is reverse of removal. The BS paint is a pretty close match. Generic Bimmian installation instructions HERE in pdf format.
Bill- 2005 Mini Cooper S, 2013 Corvette 427
www.billswebspace.com/bmwindex BMW CCA Member # 389948
      09-18-2008, 08:22 PM   #16
FrankoQ
Deny everything
FrankoQ's Avatar
Drives: 2006 330i; 2015 X6, S1000RR
2015 BMW X6  [0.00]
2006 330i  [0.00]
Looks great.
I need a drink
      04-13-2011, 06:06 AM   #17
Alexxxx
Alex
Alexxxx's Avatar
Drives: E36 Compact 318ti
Thank's for help.
      04-14-2011, 04:08 AM   #18
Haagen-Dazs
Drives: Apollo 13
I wonder how it's going to be like when your car batery dies and you have to get inside.
      04-14-2011, 02:34 PM   #19
BMWsky
Drives: 335i
Trunk?
      04-14-2011, 02:43 PM   #20
Haagen-Dazs
Drives: Apollo 13
Originally Posted by BMWsky View Post
Trunk?
No batery the trunk doesn't work. It's electro-mechanic.
      04-14-2011, 02:44 PM   #21
BMWsky
Drives: 335i
There's a key latch.
      04-14-2011, 02:47 PM   #22
Haagen-Dazs
Drives: Apollo 13
Does it work when the battery is dead?
