M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Clutch Delay Valve on M2
      09-22-2016, 11:29 AM   #1
BruceM
Drives: '17 6MT MG M2,930,Jag XKR 5.0
Does the M2 have one? Has anybody removed it or modded it? In some cars it can be a great mod...
      09-22-2016, 11:57 AM   #2
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
Doesn't have one
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
BruceM984.50
Bosozoku693.50
      09-23-2016, 10:22 AM   #3
gmzanatta
gmzanatta's Avatar
Drives: LBB 6MT M2 # 660/713
No CDV, but I would highly recommend the BMS clutch stop due to long pedal travel.
      09-23-2016, 10:51 AM   #4
BruceM
Already bought a UPC, which has an adjustable stop in it.
      11-16-2018, 10:17 AM   #5
Proctor750
Drives: E30 M3
Yes, it appears that the part numbers for clutch slave cylinder are the same between M2C and:
1' F20   (11/2011 — 02/2015)
1' F20 LCI   (06/2014 — 08/2018)
1' F21   (12/2011 — 02/2015)
1' F21 LCI   (07/2014 — 08/2018)
2' F22   (10/2012 — 06/2017)
2' F22 LCI   (09/2016 — 08/2018)
2' F87 M2   (11/2014 — 06/2017)
2' F87 M2 LCI   (09/2016 — 08/2018)
2' F23   (03/2014 — 06/2017)
2' F23 LCI   (10/2016 — 08/2018)
3' F30   (04/2011 — 07/2015)
3' F30 LCI   (10/2014 — 09/2018)
3' F80 M3   (04/2012 — 06/2015)
3' F80 M3 LCI   (01/2015 — 08/2018)
3' F31   (08/2011 — 06/2015)
3' F34 GT   (07/2012 — 06/2016)
4' F32   (11/2012 — 02/2017)
4' F32 LCI   (05/2016 — 08/2018)
4' F82 M4   (02/2013 — 02/2017)
4' F82 M4 LCI   (05/2016 — 08/2018)
4' F33   (03/2013 — 06/2016)
4' F83 M4   (06/2013 — 02/2017)
4' F83 M4 LCI   (05/2016 — 08/2018)
4' F36 Gran Coupé   (07/2013 — 06/2016)
There appears to be an internal restrictor inside of the Slave cylinder which can only be accessed by removing the slave cylinder from the trans (2 bolts) then cracking open the line to get at it.
Here is someone removing it from their F30
https://f30.bimmerpost.com/forums/sh....php?t=1486773
If you skip further in that thread it appears people just remove the metal plate and piece of plastic holding it inline altogether and re-assemble.
Figured there should be a conclusion to this thread in case someone found it as I did searching for this same answer.
BruceM984.50
AndrewC198910931.00
      11-16-2018, 08:43 PM   #6
XutvJet
Drives: 2011 Cayman Base, 2016 M235
^Yep. Your M2s have CDVs in the clutch slave cylinder.
      11-17-2018, 09:58 AM   #7
M Fifty
Drives: M2 & 330CI
Looking at that thread I wonder if just using a self-tapper into the restrictor and then pulling would be the easiest way to get rid of it.
      11-19-2018, 03:24 PM   #8
eeyang92
Drives: LBB M2 LCI 6MT
From that thread, OP mentions removing the CDV results in a smoother 1 -> 2 shift. Mechanically, how does this worK? If my interpretation of the CDV is correct, all it does it limit the rate at which the fluid can travel upon reengagement (letting out the clutch). So, if I'm letting out the clutch slowly for a 1 -> 2 shift, would I notice any difference?
I find 1 -> 2 shifts still very awkward at times (even after a year of driving my M2), but IMO it's more due to how slow the revs drop (controlled by the ECU).
      11-19-2018, 04:00 PM   #9
XutvJet
Consider the Ultimate Clutch Pedal. The pedal greatly reduces travel and puts the catch point much closer to the firewall. The pedal itself also sits lower in it's rest position. I just installed mine and man, what a difference. I'm still getting used to it, but the 1-2 shift (and all shifts) are much smoother. I've been driving sticks since the late 1980s and remained perplexed as to why BMW makes the clutch travel so long in these cars plus make the clutch pedal resting height 1/2" higher the brake pedal.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
      06-29-2019, 10:41 AM   #10
switlikbob
Chuggin' Along
switlikbob's Avatar
Drives: 2017 LBB ///M2
@xutvjet Do you have a link to where you bought the ultimate clutch pedal?
      07-03-2019, 06:07 PM   #11
imolam3
Drives: 2004 Imola M3, 2017 AW M2 PE
https://www.turnermotorsport.com/p-1...2-f22-f30-f32/
1997 Dakar M3
1999 Cosmos M3
2004 Imola M3 CSL clone
2017 Alpine White M2 Performance Edition
m2
