M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Laggy DCT
      05-22-2016, 12:45 PM   #1
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Anyone else noticing that there DCT is laggy and slow to respond. My comparison is to a 135is which also had an n55 and basically the same trans other than the software. That trans was absolutely telepathic in D anticipating what gear I wanted. Also lightning fast and firm on the shifts. The M2 in comparison is not any of this. Since it's the same trans underneath it can be fixed with software if BMW sees fit to do so. I had an option of taking my HEA M2 as is with the DCT or waiting. Since I thought the DCT in my 1 was good I figured it would be the same so took the HEA. It's not. If they don't fix it I'll be in the camp of wanting the manual.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      05-22-2016, 01:58 PM   #2
MR.
MR.'s Avatar
Drives: BMW M2 CSL Turbomeister
Not in my car... Do not have that feeling at all.
MR
      05-22-2016, 02:48 PM   #3
Pyrat 2
Pyrat 2's Avatar
MR
Hmm. Most of my complaints are in D. Still true? For example, I can be hard on the throttle and if I blip the throttle back just a bit for a moment and then back into it the car won't shift up. On my 135is it took that as a queue that I wanted to upshift and not wait until 7k which is out of both the torque and horsepower curve.
      05-22-2016, 03:57 PM   #4
MR.
MR.'s Avatar
I would need to try that when I am back with the car later this week. I hardly use D, only during the running in time but at that time I was not allowed to go higher than 5,5K.
I use the paddle shifters behind the wheel constantly the last few days and it goes into Sport mode immediately when I enter the car. Does Sport or comfort make any difference for you?
MR
      05-22-2016, 04:11 PM   #5
Pyrat 2
Pyrat 2's Avatar
MR
Does it go into sport by itself??? Or you put it in when you get in. Comfort is very bad and sport is marginally better.
      05-23-2016, 12:42 AM   #6
MR.
MR.'s Avatar
Nope, I push the button every single time
MR
      05-23-2016, 02:36 AM   #7
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
I drive in comfort 60% of the time with no issues at all. It is almost as smooth as the 8-speed AT when cruising and works great for dynamic driving too.
The only issue all double clutch gearboxes have is low speed (< 15 mph) driving as they can't predict the next gear very good.
      05-23-2016, 10:30 AM   #8
Franklin Joseph
When i'm in comfort and in D, and i try to shift...it does lag a little. But when i'm in sports+ and shift under load (@ 5000rpms) shift is good and hard.
      05-23-2016, 05:27 PM   #9
confusion
confusion's Avatar
Drives: 2016 M2
Same
      05-23-2016, 05:32 PM   #10
badluck
badluck's Avatar
Drives: E46 M3
this has me worried now, i just put a deposit down on a DCT. I havent tested the m2 but Ive driven a late e92 with DCT and loved that.
      05-23-2016, 10:12 PM   #11
koastal
Australia
376
Drives: F87
Its only laggy in comfort / auto mode ive found. I dont use those modes.
      05-23-2016, 11:34 PM   #12
twboy1999
Drives: 1994 honda accord
not laggy at all here
if you are driving slowly, it will shift softer, the harder you drive, the harder it shifts
2019 M2 HS 10000km and counting
      05-24-2016, 12:40 AM   #13
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Try doing a throttle body adaption reset and then maybe a gearbox adaption reset too
      05-24-2016, 05:20 AM   #14
Pyrat 2
Pyrat 2's Avatar
Tried the TBA yesterday. No change. How do you do the gearbox adaptation?
      05-24-2016, 05:22 AM   #15
Pyrat 2
Pyrat 2's Avatar
Remember I'm coming off if a 135is DCT so am familiar with how it can perform. The M2 just doesn't perform nearly as well.
Anyone coming off a 1er DCT with ppk here? Just wondering if my DCT is the same as yours but you all don't have the same reference point for comparison.
      05-24-2016, 08:03 AM   #16
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
I had a DCT 135i with PPK installed, i pick up the M2 this weekend so will be able to report back soon.
My car suffered terribly from throttle lag though when accelerating from low speed, was soo annoying, am praying the M2 is not the same, DCT shift speeds on the other hand were perfect.
      05-24-2016, 08:40 AM   #17
Pyrat 2
Pyrat 2's Avatar
Looking forward to hearing back from you. I had no throttle lag on my 135is and shifts were perfect. Congrats in advance on the M2.
      05-24-2016, 09:54 AM   #18
David1
David1's Avatar
Drives: 09 E92 09 X5
Don't use comfort. It's called comfort for a reason. The DCT is not the same as the old cars nor is the programming.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      05-24-2016, 11:13 PM   #19
twboy1999
i made a little video for u
i couldn't really push it, but u could see how the DCT shift
      05-25-2016, 05:20 AM   #20
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
If DCT is the same as sport auto - disconnect battery for min. 30mins - reconnect and then drive it to see if DCT shift is any better
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      05-25-2016, 06:02 AM   #21
135iDCT
135iDCT's Avatar
137
Drives: 135I
I notice the more u go on throttle the faster the DCT shifts, when light throttle it shifts slower
      05-25-2016, 06:04 AM   #22
Pyrat 2
Pyrat 2's Avatar
Was that in D? Sport? If so mine winds up way past that under what sounds like equivalent acceleration. Probably 5500 to 6k rpms.
m2
