M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Intake Tune Exhaust
      05-03-2016, 03:39 PM   #1
kevlee23
kevlee23's Avatar
72
Drives: 2008 e92 335xi, F87 M2 AW EXEC
Intake Tune Exhaust
so just wondering can I get an intake from the m235 and it direct fit and what JB4 do I look up to buy also just want to double check before buying parts
      05-03-2016, 04:05 PM   #2
wakeofdeath
Albania
71
Drives: X6M
Intake might not add much for the value, get a Dry filter instead
      05-03-2016, 04:17 PM   #3
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
OEM intake should flow better and be less prone to heat soak. It's similar to the mr.5 intake from the factory. The filter is already dry as well.
Comes down to sound vs power
      05-03-2016, 10:35 PM   #4
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
IND tested it out and it uses paper filter
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      05-03-2016, 10:44 PM   #5
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I guess that's what I meant by dry. Paper dry haha. Different than some I assume.
      05-04-2016, 01:57 AM   #6
ABPReader
Deserter
ABPReader's Avatar
Drives: BM&W
On the M235i, you don't have gains with the intake. Better sound only but it is subjective. It will probably be the same with the M2.
      05-04-2016, 09:51 AM   #7
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Hardly, Mr.5 was an extra hole with ducting to a dedicated filter that added much more cold air into N54 air box.
M2 lower airbox is the same as F30 N55 MPPK lower airbox ie big red hole directly behind LH headlight.
I tried F30 MPPK airbox on M135i with Jb4 and found it added nothing compared to std N55 airbox and a drop-in. I swapped back and installed an AFE DAS behind LH grille to help direct air into airbox, adding positive pressure to help flow thru an AFE dry drop filter panel. In mine and others have found DAS helps throttle response and even adds something to keeping IAT's in check. Great $50 mod for the sealed lower airbox
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      05-04-2016, 11:31 AM   #8
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Wait, those Air Scoops that everyone bought? I thought those actually did nothing. I glad some platform has found use for them.
Thanks for the response! What I meant by Mr. 5 is that it has a whole in the airbox like that intake. It doesn't have a dedicated filter but it helps direct more air into the airbox. It wouldn't be there if that wasn't the case.
      05-04-2016, 11:39 AM   #9
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
But that doesn't go without saying that the airbox could be there purely for sound. It wouldn't surprise me. I think my main point here is that your not going to see high/if any gains. As you pointed out.
If you have a Pure stage 2 or something similar that's a different story.
      05-05-2016, 02:30 AM   #10
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
You're one of the few on the forums to say they work! Everyone just bashes them and says they don't work at all blah blah. Nice to know. Might pick one up now.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      05-05-2016, 03:24 AM   #11
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Yep - I found a use for an air scoop - inlet side of the turbo responds well to more air I agree but it seems like positive pressure more ie throttle is sharper with sealed lower box and DAS than with MPPK lower airbox and no scoop. To help, perhaps take a look at YT video by Evolve.
Stick with hole in the airbox fella, given its OEM for more intake noise an M2 !!!
      05-05-2016, 04:15 AM   #12
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
The YT embedded in my post above may help your decision......
      05-05-2016, 04:28 AM   #13
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Just ordered one!
Edit: Also going withAFE open air intake extremely soon.
m2
