BMW 3-Series (E90 E92) Forum
Shutter/hesitation from staggered wheels
04-18-2016, 04:32 PM | #1 |
Rep 272
Hey all. Having an odd issue where upon acceleration, the car stutters or hesitates. It only happens when I put on my staggered wheel set up. I have had the wheels for almost four years but the issue started last summer. It happens about 50% of the time and more so during hard acceleration. No lights on dashboard. I attached a copy of the original invoice that has the wheel and tire sizes. Ordered them from a vendor of this site a few years back. Any thoughts? Car is awd btw.
Afe Stage 2 Magnum Intake - Custom SS Exhaust - AG M359 Staggered - CF spoiler
04-18-2016, 05:13 PM | #4 | |
Rep 272
04-18-2016, 05:59 PM | #5 |
Rep 2,835
You will need to find out specifically from the manufacturer how many revolutions each tire will make in a mile at what tire pressure.
Also, is this a manual or automatic? |
04-18-2016, 06:19 PM | #6 | |
Rep 272
04-18-2016, 06:27 PM | #7 |
just another bmw douche bag
195
Rep 3,640
I suspect that with your staggered setup, there is a slight difference in the rolling diameter between the front and rear wheels. If it's a very small difference, all systems work fine.
Now that your rear tires are worn down more, the difference is starting to approach the threshold where things are not fine, and it's starting to trip the computer. if the sizes between front/rear become too large, you risk damaging your center differential, so keep that in mind. having the same size tires all the way around is very important on an AWD car. |
04-18-2016, 06:43 PM | #8 |
Rep 712
Had the same issue when installed 19's on my GTI. Shop installed the wrong size hub centric rings. It was off by a mm or two but it made a difference. Do you have rings installed?
04-18-2016, 06:55 PM | #9 | |
Rep 272
04-18-2016, 06:57 PM | #10 | |
Rep 272
