      03-14-2016, 11:56 AM   #45
novablackm3
Drives: Performante, G05 M50i, RR SVR
Originally Posted by Cattivo View Post
I highly recommend this mod
Did you guys use the e70 pads
      03-14-2016, 12:37 PM   #46
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Originally Posted by JupiterBMW View Post
Yeah, last week my truck was on the lift getting the new Michelin PSS installed... I was checking the rotors and I too will be in need of rotors soon, at least the front two... UGH...
How do you like the PSS' compared to the Dunlop RFTs?
      03-14-2016, 02:21 PM   #47
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
How do you like the Honda Ridgeline compared to the BMW X5M?
Lol! Seriously though, quieter, lighter, smoother, and definitely great for grip. I find myself driving that thing like it's a car now...
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      03-14-2016, 03:09 PM   #48
Cattivo
FDNY Engine 55
Cattivo's Avatar
I re-used the original pads(OEM)
      03-20-2016, 10:06 AM   #49
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Just had the F85 X5M Rotors installed...perfect fit
Cattivo, how much was the whole package? 2700 sounds a little outrageous. I was expecting 800.
      03-20-2016, 10:08 AM   #50
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Nice I have a set of 21" Mich PSS im throwing on the car next week. ill let you knw what i think bc im one if the few that the rfts dont bother lol.
      03-20-2016, 11:33 AM   #51
Cattivo
FDNY Engine 55
Cattivo's Avatar
I bought them used with only 5k miles on them for under $1k
      03-20-2016, 07:46 PM   #52
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Originally Posted by XFIVEM View Post
More pics
How are those rotors holding
up over the winter? Is there any corrosion starting on the hats?
On another note, if I understand correctly there is nothing holding on the rotors except the wheel lugs? So when you change a tire for example
the rotors may come off? Am I missing something?
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      03-21-2016, 07:42 AM   #53
Crazy1323
Drives: X5M
I believe there is a small retaining screw that holds the rotor to the wheel hub. However I've run other cars where the only thing holding the rotor was the lug bolts and never had an issue when changing tires.
      03-21-2016, 07:42 AM   #54
mirob
mirob's Avatar
Drives: M3CX
The rotors are still held in place by the housing that has the brake pads. So no, the rotors won't come off when you remove the wheels. The wheels/lugs just secure them further.
      03-21-2016, 11:01 AM   #55
denaliman
denaliman's Avatar
2013 X6M  [0.00]
Thanks.
      03-21-2016, 05:00 PM   #56
Cattivo
FDNY Engine 55
Cattivo's Avatar
Rotors are holding up fine with no corrosion after a few months of winter/salted roads in NYC. I'm swapping the winter set to summer set up tomorrow, I will take a few pics to give you a better idea if you want
      03-21-2016, 08:06 PM   #57
denaliman
denaliman's Avatar
2013 X6M  [0.00]
That would be great. Thanks. Looking forward to pics without wheels installed.
      03-22-2016, 07:07 PM   #58
Cattivo
FDNY Engine 55
Cattivo's Avatar
I took a few crappy iPhone pics of the rotors w/o the wheels...with spacers...with the new wheels mounted. The rotors do not fall off once you remove the wheels, the brake calipers hold them tightly in place...hope this helps brother
      03-22-2016, 08:34 PM   #59
denaliman
denaliman's Avatar
2013 X6M  [0.00]
Thanks for the pics. Ride looks great. I do like the high polished look of the rotor hats on the original rotors better. Although the f85 rotors are probably less weight.
      03-23-2016, 03:08 AM   #60
Cattivo
FDNY Engine 55
Cattivo's Avatar
Thanks, the original rotors were a lot heavier with a nicer finish although the F85 rotors not only look better, they seem to stop the beast a lot better
      03-23-2016, 12:13 PM   #61
p66
Drives: 1M
Rotors are held in place on hub by two set screws. Lugs provide the necessary clamping force. Calipers are not connected to rotor other that the brake pads.
      03-23-2016, 01:51 PM   #62
boneca
boneca's Avatar
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
I'll be def looking in to upgrading my rotors to F85 as well, when the time comes to change them, I should be good for another 10K-15K I think, but the way it goes I can be there pretty quickly
I have a question, there is a pretty big list in the screenshot on the first page, I just want to know if all those parts are needed to upgrade?
so we need:
4 rotors (2 front, 2 back)
2 sets of pads (front and back) these can be from either E70 or F85?
2 sets of sensors (front and back) 4 sensors?
4 new bolts?
      03-23-2016, 09:44 PM   #63
X-static
Drives: 2011 X5M Melbourne Red
Just an educated guess here...my '11 X5M only has one sensor on front and one rear. The pads need to match the caliper and rotor, but have to attach to the caliper, so I would expect to use pads from the year/model that the caliper originates from. This looks nice, but I would be concerned about pads/rotors not matching perfectly from two different models. Less contact area equals less ability to stop.
      03-24-2016, 05:11 AM   #64
theaudir8fan
theaudir8fan's Avatar
Drives: a major headache
looks good, however i wonder if there is a issue where you could spin the rotors freely since the screws aren't there to hold the rotor and as a result cause major pain when trying to line up the wheels rotor and hub for putting in the lug bolts during wheel swap
      03-24-2016, 03:31 PM   #65
Cattivo
FDNY Engine 55
Cattivo's Avatar
Thanks, both front and rear rotors held in place very firmly while mounting the wheels. The rear wheels were a lot easier to mount since the spacers were bolted to the rotor, the front wheels were a major pain in the ass trying to line up the bolts and keep the spacer from spinning, my best advice would be to get a second set of hands to help with the big awkward and heavy 22'' wheels...I sat on the ground lifted the wheel onto the hub and controlled it with my thighs fighting to get the bolts in
      03-24-2016, 03:54 PM   #66
Cattivo
FDNY Engine 55
Cattivo's Avatar
so we need:
4 new bolts?
You will need front and rear F85 rotors, re-use the original pads, sensors and bolts...everything lines up 100% except for the set screws. I've pushed the beast past 130mph with aggressive breaking since installing the new rotors with no issues whatsoever
