BMW 3-Series (E90 E92) Forum
[Solved] 2006 BMW 330XI noise diagnosis
11-03-2015, 08:00 AM | #1 |
Rep 35
Brought my 2006 BMW 330XI to BMW Dealer.
== Cause == "Found internal fault for transfercase. ", Dealer's report suggests "replace transfercase and mount" then "reprogram vehicle DSC". I don't know how BMW technician checked my car... Probably they just scan the codes and cleaned my wheels... Shinny! == Question == Could it be just "transfer case actuator" instead of the whole transfer case? How to diagnose? Or, In general, How to proceed in such a case? Thx! ========= Update ========= Last weekend, I did two things: 1) Flush the Diff oil. 2) Rotate tires from Rear to Front, Front to Rear; and inflate the tire pressure to specs (32 psi (F), 36 psi (R)) Noise was gone. Should I dispute the BMW dealer's diagnosis charge which detects a "Transfer Case Internal Error" and suggests to replace the whole Transfer Case for $4000!?? Last edited by bmwsucks2; 11-09-2015 at 08:18 AM.. |
11-03-2015, 01:48 PM | #2 |
Rep 164
Based on this DIY, I would say it's worth a shot: http://www.e90post.com/forums/showthread.php?t=633200
11-04-2015, 12:35 PM | #3 |
Rep 35
TheBigYhi, thanks very much! This is definitely worth a shot. I will take the actuator off to take a look. I planned to replace the Tcase fluid anyway...
11-04-2015, 06:23 PM | #4 |
Rep 35
TheBigYhi, a quick question, I read the DIY. But in my case, there's no any lights on, only grinding noise. It gets louder at 40 - 50 MPH. If tcase failed, should there be any lights on? Thx!
11-09-2015, 08:19 AM | #5 |
Rep 35
Besides Diff Fluid, I also bought Brake Fluid and TCase fluid. Will flush them some day when car hits ~80K.
Thanks to TheBigYhi! This is a better place than BMW shop! |
Tags |
bmw 330xi noise transfer case |
