Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > Sirius Plug and Play Install
      01-20-2008, 11:20 PM   #1
E92Vancouver
E92Vancouver's Avatar
33
Drives: 2000 E46 & 2007 E92 328
I decided to install satellite radio. The dealer wants about $900 for the BMW module that intergrates with the OEM stereo. I decided to go for the $49 Best Buy option.
As I do not like wires and cables, I decided to hard wire the unit in. The first thing I had to do was create a wiring harness from the adapter that was provided. This adapter steps down the vehicles voltage to 5V.
I hardwired the harness to the fuse box. The antenna was mounted on the rear deck secured by velro and the wire hidden in the molding or carpet seams.
The power wire, line in wire and antenna wire were all hidden. The antenna wire was run from the rear deck, down the drivers side, under the front seat rails, under the carpet up to the centre console. From the centre console, the antenna wire it was run along the transmission tunnel under the molding up to the area by the heater core, then down between the two vents (that supply air to the rear seats) to the ashtray. The wires have to be out of the way of the clips that fasten the console trim.
The wiring harness was run from the fuse box to the centre console area. There is a corner hole to run this wire through and keep it out of the way.
The line in wire was run up to the ashtray area, tucked under the molding on the left side of the shifter.
A hole was drilled in the ashtray and the 3 wires pulled up.
Some of you will comment that the wiring harness has electrical tape. I soldered the joints, used heat shrink and then to be extra anal, used electrical tape over the heat shrink.
If you notice two fuse taps in my fuse box it is because one runs my radar detector.
I love the fact that the display is big, the unit is portable to the house or summer cottage and there is a remote control.
If anyone has any questions or needs more pictures, I will post them as needed.
      01-20-2008, 11:24 PM   #2
Zeiss
Zeiss's Avatar
Drives: Bicycle
Good work!!!
      01-20-2008, 11:56 PM   #3
Kloogy
Kloogy's Avatar
Drives: 2011 BMW X5 Sport
I was thinking of a good lacation to mount such a unit if I decided to not go the BMW OEM route. That's a great location you picked. Thanks for the pics and info ! My only question is how is the reception with the antenna mounted inside the vehicle ? In my Mustang GT I had an issue when I put it inside the car like you did.
      01-21-2008, 12:07 AM   #4
E92Vancouver
33
Reception has been fantastic. I even get reception in the garage. I think the Sirius signal is distributed fairly efficiently and has good coverage. 90% of the time I am getting the full 3 bars. At worst, it is briefly 2 bars but still sounds great.
      01-21-2008, 12:13 AM   #5
Kloogy
Kloogy's Avatar
I've got 4 active radios with them, and I'm suffering in my 328 without it. Thanks again for the ideas.
      01-21-2008, 01:24 AM   #6
aequitas330
Montego Blue FTW
aequitas330's Avatar
56
Drives: Montego Blue e90 328xi
Nice...
Sig designed by Nikki:
      01-21-2008, 03:01 AM   #7
E92Vancouver
33
Here are some more photos.
      01-21-2008, 03:02 AM   #8
E92Vancouver
33
Some more photos again.
      01-21-2008, 03:04 AM   #9
E92Vancouver
33
Originally Posted by BNR32 View Post
Good work!!!
More install photos.
      01-21-2008, 03:07 AM   #10
E92Vancouver
33
The last of the photos.
      06-16-2010, 09:00 PM   #11
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Thanks for posting this man, I am about to go this route as well and you have saved me a bunch of time with the write up
2019 M5C Matte MBB / Tartufo
      06-19-2010, 02:43 AM   #12
E92Vancouver
33
Thanks. Here are the more detailed installation instructions:
http://www.e90post.com/forums/showthread.php?t=111595
Please post a comment to the above thread as it is more relevant.
      06-23-2010, 04:09 AM   #13
Hazard83190
Drives: 2008 E92 335XI
Nice!
Matthew C. Friedberg
