BMW 3-Series (E90 E92) Forum
HELP! Oil around Intake Manifold Sensor
12-21-2014, 11:29 AM | #1 |
Enthusiast
167
Rep 1,622
I noticed today that there was some oil around the sensor on top of the intake manifold on my 335i N54. I has no idea how it could have gotten there? Has this ever happened to anyone? There a leak somewhere Im not seeing? I checked everywhere around it and only oil around the sensor. I have attached pics of what Im talking about.
Also my coolant reservoir is completely empty. I filled it up about 2 months ago and its empty again, I dont see any leaks anywhere, any ideas what the cause might be? Thanks for you help! Rik |
12-21-2014, 11:39 AM | #2 |
Rep 2,731
spray it clean with brake parts cleaner or castrol super clean. then inspect it again with a flashlight after a couple days, see where the leak is coming from.
let us know how it goes. |
12-21-2014, 11:43 AM | #3 |
Enthusiast
167
Rep 1,622
Will do, thanks for the input! Also could that sensor be leaking oil somehow? What exactly does that sensor do?
12-21-2014, 11:46 AM | #4 |
Professional Monkey Trainer
65
Rep 423
It measures intake pressure. Its a MAP sensor. It could be leaking under boost. Pull it out and inspect the O-ring. If it looks suspect replace sensor or replace O-ring.
12-22-2014, 10:38 AM | #6 |
Enthusiast
167
Rep 1,622
12-22-2014, 11:07 AM | #7 |
Rep 208
definitely take care of that sensor. Clean it well, change O-ring or even replace the whole thing. I went crazy trying to solve a low boost code on high rpm in my car. It turned out i had a fouled MAP sensor due to oil. I replaced it and back up to full boost!
AW E92 M3 DCT /// |
12-22-2014, 11:46 AM | #9 |
Enthusiast
167
Rep 1,622
Think Im going to be replacing it! thanks guys!
