BMW 3-Series (E90 E92) Forum
Rear Wheel Bearing Life
11-08-2014, 03:40 PM | #1 |
Rep 41
Hi,
Just replace both rear wheel bearings on my 335. The car has 85k mile and the failure seems premature. All races had significant fretting. ID & OD, inner & outer on both sides. Car is a one owner 07 6sp that has never been tracked and has mostly freeway miles. Has anyone else had such a failure? See photos. Thanks |
11-08-2014, 05:17 PM | #3 |
BMWCCA 149159
38
Rep 847
BMW has a tendency to under lubricate their bearings. Just visit E36 and E30 forums. Some have gone to inserting synthetic grease with a needle into the replacement bearings because of this.
I have replaced countless bearings on BMW 3 series and some of them are almost impossible to get out even with a torch. Most show wear as yours does but much much worse and typically even with the bearing removal tool the bearing comes out in pieces... |
11-09-2014, 01:18 AM | #6 |
Rep 1,117
Drives: 2010 E90 328i 6MT ZSP BSM
I had my 2010 E90 328i rear right wheel bearing replaced recently at about 100,000km (about 63k miles). It was making a loud droning noise as I go over 25mph and the noise was unbearable at highway speeds.
11-10-2014, 09:25 AM | #10 |
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
I had my rear wheel bearing on the driver's side go out around 80,000km.
I had it replaced at the dealer out of warranty (at my cost!), and it then went out 20,000km later. Thank God for that 2 year warranty, it was replaced again at that point. Now, at 140,000km, they've all been fine. I think some are just defective. |
11-10-2014, 12:21 PM | #11 |
Rep 669
different car, but, I had done a front wheel bearing replace and the new one started making noise less like 5 months after.
Could have been the part, or the wheel hub install, or the excessive torquing of the wheel hub nut. Second time around I did it right. No more probs. |
