THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Exhaust only out of one side
      09-08-2014, 07:53 PM   #1
horsepower_and_hounds
1st I will say is I thought I knew how the exhaust should work but I am 675mi into my break in period and i don't think the l/h side of the exhaust has opened. I have been in comfort mode for the whole time...does it just open in sport? Need to be driven hard? I did a long highway drive Sunday and when I pulled onto my street I stopped and checked the outlets...the left side is completely cold. The right has some soot in the pipe but the left side is completely virgin...
Can someone enlighten me?
      09-08-2014, 08:02 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
i think it only opens when you push it over 4k rpm
      09-08-2014, 08:37 PM   #3
nzw212
Drives: M235XI, Maserati, Ducati
Is this true?
      09-08-2014, 08:51 PM   #4
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
The left side valve open rate is heat related and it takes place up front with aux pumps...so go in and have it checked. I know of three in our area, and they all have left side open up in about 35 to 40 seconds. I don't think comfort as anything to do with it...but I could be wrong on that. The electronic action back there on left side is actuated by up front temps in intake.
      09-08-2014, 09:09 PM   #5
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Originally Posted by nzw212 View Post
Is this true?
It is my understanding also that in comfort it only opens above 4k rpm.
      09-08-2014, 09:39 PM   #6
Killramos
Killramos's Avatar
Drives: '19 M2 '21 X5
It opens in sport all the time. Exception to this is it is shut during startup in order to create more resistance to warm the cat up from what I understand. Same reason the car settles into a lower idle. Helps emissions.
      09-09-2014, 07:49 AM   #7
That is what I want to hear....I will re-evaluate when it is broke in. Right now i only drive in comfort and below 4k per instructions. I try to vary the load the best I can and am not using cruise.
I had noticed after my 1/2hr drive home the l/h exhaust pipe was cold.....and there is absolutly no exhaust residue inside like it is brand new. I am at 690mi so half way. Lookinfg forward to the 1200 milestone
      09-09-2014, 09:16 AM   #8
Jerich0
Love to Drive
197
Drives: X4 & M4
I studied the exhaust valve issue as well here are my results:
Exhaust valve closed when cold startup for 15 - 20 seconds and then opens.
Valve open ALL THE TIME at least on idle on any driving mode. (When engine warmed up)
Temps in my area are around 75-90F
      09-09-2014, 12:39 PM   #9
Now that is not what I wanted to hear.........interesting. Maybe I need to choke the chicken to break it loose
      09-09-2014, 07:48 PM   #10
Ok so today I drove home in sport mode..."very easy" to abide by the break in rules and the exhaust was open when I pulled into the driveway. I looked up the exhaust and it was barely cracked open so I guess it opens and closes based on a bunch of parameters. All i know is that it never opened in comfort mode driven easy. At least I know it works....
      09-09-2014, 09:31 PM   #11
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Which side closes...passenger?
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      09-10-2014, 03:09 AM   #12
driver....the side with the flapper
      09-10-2014, 12:31 PM   #13
Jerich0
Love to Drive
197
Drives: X4 & M4
To me when its open its quieter... Closed is louder!
      09-10-2014, 01:40 PM   #14
ciwhamc
Drives: M235i Alpine White
2014 BMW M235i  [0.00]
It is. Open is the longet quieter side of the mufler closed is the short loud side.
      09-21-2014, 12:38 AM   #15
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Do you know if the performance exhaust works the same way? Or does this one is open all the time?
2addicts
