THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Factory exhaust + Performance Carbon Fiber Tips: can it be done?
      09-04-2014, 06:02 PM   #1
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Many people here went to the Performance Exhaust and installed back the factory black chrome tips. But I'm going the other way, I'm keeping my factory exhaust but wanting to install the Carbon Fiber Tips.
I've read on ebay sites that "it cannot be done", but I need your input to confirm if it is true that no way you can do this. Truly appreciate your feedback!
      09-05-2014, 06:41 PM   #2
AlexGT
AlexGT's Avatar
Guatemala
420
C'mon guys, anyone? help this newbie to learn hehe
      09-05-2014, 08:23 PM   #3
kerm1t
Drives: 17 M3 ZCP Stage 2
i guess an easier question would be, will the MP chrome tips fit the stock muffler? if yes then the CF tips should fit as well.
      09-05-2014, 08:32 PM   #4
AlexGT
AlexGT's Avatar
Guatemala
420
You're right, I screwed up with the initial question, thanks.
So, will it fit? LOL!! C'mon, somebody must know!
      09-06-2014, 02:56 AM   #5
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Stock tailpipe dia is 60mm
MPE tailpipe dia is 67mm
MPE trims are concentric and fixed by a grub screw on the underside.
If you used a packer sleeve 1/8th" thick slid over stock tailpipe, with a slot at 6 o clock position to allow grub screw to pinch tailpipe outside diameter, then MPE trim could be slid onto tailpipe and packer and secured with grub screw (you may have to get a longer grub screw)
      09-06-2014, 09:07 AM   #6
AlexGT
AlexGT's Avatar
Guatemala
420
Pave, many thanks for the reply and the detailed explanation! I will give it a try then!
      09-06-2014, 12:01 PM   #7
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
Alex,
No problem. Let us know how you get on.
PD
      09-06-2014, 02:34 PM   #8
AlexGT
AlexGT's Avatar
Guatemala
420
Will do Pave, cheers!
2addicts
