THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Another launch control thread
      08-08-2014, 07:24 PM   #1
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Yes, this is another one...
I am having an issue with the launch control to activate. In fact, I still have not been able to have it activate once. My car has nearly 6,200 KM's ( 3800 miles)
Here is what I've done...
Drove for nearly 20 minutes in 80*F weather / Drove for 10 minutes in 80*F weather.
Ensure steering wheel is dead straight
Sport + or regular sport mode than turn off traction control.
Toss paddle to manual shift mode
Step on brake, hard.
Step on gas, firmly.
I get nothing... Just tons of wheel spin, the RPM's flaring to 6-7k
I have JB4 stage 2 - could this be causing any issue?
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com
Current: 2015 Cayman S on HRE P101
      08-08-2014, 07:36 PM   #2
plien69
Drives: 2014 M235i
Couple things that might be interfering (besides JB4, which I don't know anything about):
Move shifter left to Sport shift mode (S1, S2, etc.) but do not use paddles to engage Manual Shift mode (M1, M2, etc.)
When you step on the gas, make sure you press all the way down past the kickdown button. Do it fast, and the engine doesn't have time to rev past the launch hold RPM. I Launch Mode doesn't activate unless the kickdown button is down, so if you try to feather the throttle, you'll end up revving up past 3.5k and the wheels could start spinning.
      08-08-2014, 08:16 PM   #3
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
Ya... you don't really need neither sport nor sport+
hit DTC button once
shift lever to the left to (DS mode not manual) don't touch paddles
foot on the brake all the way
foot on the throttle activating kickdown
and you should see the launch control notice on the cluster, release the brake within 5 secs and off you go....
you need to at least have driven 6 miles and oil be at temperature and I think you need to be over 2000miles on your car
      08-08-2014, 08:36 PM   #4
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Yup, doing all of that. I don't engage paddles, I send the shifter to the left.
I push the throttle down quite quick, almost how you ease into a WoT - not absolute mash but you throttle down within .5 seconds.
      08-08-2014, 08:57 PM   #5
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
You have to mash. There is a kickdown trigger at the end of the throttle that needs to be depressed.
      08-08-2014, 09:01 PM   #6
Demetrius Joel
Drives: 2014 BSM/CR M235i
2014 BMW M235i  [0.00]
Didn't know I had to be over 2000 miles. Prob why it didn't work for me.
      08-08-2014, 09:02 PM   #7
pikcachu
pikcachu's Avatar
1403
don't quite remember the exact limit but it's 1200 or 2000
looks like 5000km from this
http://www.2addicts.com/forums/showp...95&postcount=9
      08-10-2014, 09:02 AM   #8
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Got it to work. Really don't be scared to mash the pedal quickly to the ground than you will see the flag appear and enjoy the ride!
      08-21-2014, 11:18 AM   #9
ctgilles
ctgilles's Avatar
62
Drives: 2019 F87 M2C
Bear in mind that it's limited to 100 launches before it will disable this function.
      08-21-2014, 11:27 AM   #10
pikcachu
pikcachu's Avatar
1403
Any idea if it counts if you abort the launch... meaning don't release the brake and let off the throttle ?
      08-21-2014, 12:26 PM   #11
Killramos
Killramos's Avatar
Drives: '19 M2 '21 X5
Source?
Remember this is not the same as dct transmission.
      08-21-2014, 12:39 PM   #12
ctgilles
ctgilles's Avatar
62
Hi Killramos, this was said during my sales training last May when we were talking about the sports automatic at BMW Belgium-Luxembourg. Someone will have to test it then (I have used it about 5 times in 2 months but I don't do drags, only trackdays.)
      08-24-2014, 08:25 AM   #13
plien69
Drives: 2014 M235i
Some LC vids I made a week or two ago:
In Comfort:
In Sport+ with wheelspin off line:
In Comfort:
In Sport+ with no wheelspin:
      08-24-2014, 10:46 AM   #14
pikcachu
pikcachu's Avatar
1403
Interesting... so you only get wheel spin in sport+ ?
that could explain it... as launching in sport+ you would have stiffer suspension setting so it will bounce more and prone to wheel spin while on softer suspension it would bounce less and suspension would absorb it
      08-24-2014, 02:14 PM   #15
plien69
Drives: 2014 M235i
I haven't done enough launches in controlled settings to be able to say for sure Sport+ = wheelspin. It could very easily have just been the tarmac properties at that particular location.
2addicts
