THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning ER intercooler, chargepipe, downpipe, before and after logs
      07-13-2014, 05:42 PM   #1
rwalker
Drives: the wheels off
This weekend I went near FBO using the ER parts in the subject. I also hooked up my JB4 FF lines.
I'm very happy with the quality of ER's parts, thoughtfulness of installation instructions, and the results, which speak for themselves. Thanks also go to Mike@N54Tuning for a great price and speedy delivery.
before_ER.xls: JB4 with EWG on map2
after_ER.xls: same as above + FF and the ER bits
The runs were completed 2 days apart and represent identical prep, weather conditions, and test methodology. The parts of the logs I've screencapped for you below represent an initial romp (fully warmed up) and a fully heatsoaked uphill run.
As you can see, timing, PWM, and IAT are dramatically better with the upgrades.
Fuel was 91oct + a can of NOS race octane booster. Ambient temps were 75degF.
      07-13-2014, 06:54 PM   #2
kerm1t
Drives: 17 M3 ZCP Stage 2
before ER mods you were running map 2?
      07-13-2014, 07:09 PM   #3
rwalker
yep, all good with EWG and 94oct
      07-14-2014, 07:41 AM   #4
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
PWM seems higher than stock? Which means turbo has to work harder?
      07-14-2014, 07:42 AM   #5
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
IAT flat...impressive. I didn't know ER was selling an IC.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      07-14-2014, 01:28 PM   #6
kerm1t
did u notice a big difference between map 1 and map 2?
      07-14-2014, 01:34 PM   #7
rwalker
noticed about 3 miles per hour (111->114) on my romp test
      07-14-2014, 02:33 PM   #8
kerm1t
oh nice. i started looking into the nos octane booster, seems kind of risky. run into any pinging issues?
      07-14-2014, 02:39 PM   #9
rwalker
Pinging caused by octane booster, or before I started using it?
In no case has any pre-detonation been audible to me, but I wouldn't expect it to given these cars' defenses against such.
      10-01-2014, 11:41 PM   #10
Yuqi
Drives: 14 335i Xdrive
Just wondering if charge pipe is necessary for JB4 map 2? Is it gonna explode?
Also intake?
      10-02-2014, 05:13 AM   #11
Chris in Japan
Drives: BMW M135i on order
Also intake?
My stock cp blew off the throttle body with such force it ripped the wires out of the sensor plug attached to the cp. This happened first track day after installing my racing dynamics r35s (similar to a jb4).
So I would say better safe than sorry.
As for intake you may gain a little at high rpms or not. I have the bms.
      10-02-2014, 05:58 PM   #12
Yuqi
Thanks a lot for sharing your experience.
2addicts
