      01-19-2020, 09:59 AM   #1
ibrother
Cambodia
Drives: 2008 BMW X5
hello all bimmers,
i would like to ask you all for the advice of my AC. the problem is when the first engine start, i have to increase the accelerator few times to get cold air. some people say the cause of the old compressor which need to be replaced. as you all know it is not cheap, so i would like to know the exact root cause. anybody has experience/advice are greatly appreciated.
2008 X5 3.0Si
thx
      01-19-2020, 02:16 PM   #2
yco
i'm just saying
yco's Avatar
5725
Drives: E71 X6M '10 (sold)
nothing is wrong with your AC ibrother..
      01-19-2020, 07:03 PM   #3
ibrother
Cambodia
Drives: 2008 BMW X5
do you have any idea what the problem is?
      01-19-2020, 10:57 PM   #4
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Sounds like your just low on freon, easy enough to top off yourself
      01-20-2020, 04:07 AM   #5
ibrother
Cambodia
Drives: 2008 BMW X5
i checked and it was low. by filling out, the issue still persists.
      01-20-2020, 02:18 PM   #6
RL18
Drives: 2011 335d sport
If your low on refrigerant the only way to fill it to proper factory spec is to evacuate the system and weigh in the factory charge. Also you could of lost some oil in the compressor which will need to be topped off. I wouldn't trust those stupid refrigerant in a cans because I'm sure bmw runs different pressures/temperatures than other manufactures, and not to mention it's technically illegal to handle refrigerant on any ac system with out a license from the EPA.
I'm all for diys but refrigerant systems should be handled by the professionals. There's a whole lot more to the process than you think. So you should have a professional licensed technician for car ac systems check to be sure your low on refrigerant and run a pressure test to be sure there isn't a serious leak.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      01-22-2020, 12:32 AM   #7
ibrother
Cambodia
Drives: 2008 BMW X5
thank you. i will bring it to check again.
RL18273.50
