12-06-2019, 12:41 PM | #1 |
Rep 84
I can smell it but I can't see it
I have replaced radiator, expansion tank, and upper radiator hose Over last few months. Most recently was the upper rad hose. Problem is after 500 miles I can sometimes still smell radiator fluid. I have looked high and low and can't find a drop. I have no cooling issues. Car runs fine. Any ideas ? Could radiator fluid found its way into the heater? I smell it most often then when heater is on. But not always.
If it?s cheap it ain?t good, and if it?s good it ain?t cheap
12-06-2019, 12:56 PM | #2 |
Rep 34
Engine coolant is what goes through the heater core, controlled by an electronic valve so there's only flow when you are demanding heating from the climate control. This is why you have to set the heater to max when you bleed air from the coolant system.
If you are consistently smelling coolant with the heater on then you likely have a leak somewhere in the heater core. Not a fun job as the entire dashboard has to come out of the car to get to it. There is also the potential that you have a leak in the engine bay and the smell is being drawn into the fresh air ducts mounted at the base of the windshield. I would try to see if the smell changes when you force the climate control into recirculate (no outside air) and also do a pressure test of the cooling system. |
NorthCountryGuy1711.00 |
12-06-2019, 01:06 PM | #3 |
Rep 4,057
Common problem after eating spicy food.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
12-30-2019, 02:26 PM | #4 |
Rep 84
Well I have done some research and be damned if I can find the issue. Although also oddly enough the problem has kind of gone away. I went on a long road trip in the Santa Cruz mountains, and it was cold and rainy as hell. Th scent eventually went away. I have since played with the controls to try and get the smell to come back but it hasn't. or it hasn't come back continuously. Maybe briefly the other day I smelled something but it wasn't pungent. Doubt anyone else would of noticed but I did, or I think i did. Cant find anything wet in the car, so doubt its a heater core leak. THANK GOD!! So thats that!
01-07-2020, 09:46 PM | #5 | |
Rep 230
