      09-11-2018, 01:20 PM   #1
Nanometer
Vice Admiral
Nanometer's Avatar
Drives: 2017 M3 Comp & 2020 X5 M50i
Coolant Leak on X5 50i (N63) 2013
Hey All! I have the described car and it has a coolant leak coming from the driver side. Approximate location is between the heater core ***** which appear to be dry, and the reservoir, so basically somewhere in that region. Do you guys have any idea what that could be? Recent replacements were Thermostat, and the "T" fittings which are on top of the engine. Engine was leak free for a few months, and then this issue popped up seemingly very suddenly. Pressure Testing at 15 PSI creates a sizable puddle pretty quickly. Really appreciate your guys' thoughts!
Potential issues: Reservoir, some coolant line that I can't see?
2017 M3 Competition | Carbon Brakes | Dinan Suspension | MHD Stage 1
2020 X5 M50i | JB4
      09-12-2018, 12:55 AM   #2
Nanometer
Vice Admiral
Nanometer's Avatar
Adding a picture. Area for leak is in red. Basically the bolt get's wet when I pressurize the system. I know it isn't easy from this picture, but hope it helps!
2020 X5 M50i | JB4
      09-12-2018, 01:41 PM   #3
Ryan5034
Drives: 2019 X5 50i
There is some sort of heater control valve down there. That might be it. Make sure your coolant expansion tank isn't cracked.
      09-12-2018, 10:42 PM   #4
Nanometer
Vice Admiral
Nanometer's Avatar
Thanks for the suggestion! I'll check the valve. I think the tank is good, the leak is much further back.
2020 X5 M50i | JB4
      09-14-2018, 02:11 PM   #5
NVS PWR
Drives: 2010 X5 M
The system is not overfilled right? Of it is ot will vent out and make a mess. Always good to check the very simple basics. Also if the turbo coolant pump is starting to fail- the system will leak when vehicle is shut off.
      09-21-2018, 10:47 PM   #6
cd85233
Drives: 2012 BMW X5 N63
Put some dye in there and let it run for a bit. Should glow like a light under UV. Doe the turbo tanks/main tank at ones.
      02-01-2019, 09:18 PM   #7
jaydavis226
Drives: M
Hello,
out of curiosity did you ever find out the problem?
I’m pissing coolant on driver side just behind the tire. I purchase dye just waiting to arrive.
I had hi temp warnings on start up so i replaced the turbocharger pump but I’m still getting waring on start up.
I also want to add the coolant level has not really dropped.
The turbocharger coolant and pump now run with zero coolant lost.
2011 n63 with 70k
      02-01-2019, 11:32 PM   #8
9vapors
Drives: CB X5M
Mine was my water pump and then coolant tank. The coolant tank leaked right in that area for me... they're prone to cracking.
      02-02-2019, 04:56 PM   #9
dennik
Drives: 2015 xdrive50i
+1 for coolant tank, i also replaced at 83kmiles
