07-15-2021, 02:43 PM | #1 |
Rep 852
Clunk when Moving in Reverse
When I shift into reverse and start moving I hear slight clunk. May this indicate any potential issues? Car is 2012 E70 35i.
I am new to E70, coming from E92, having manuals all my life. Any advise is appreciated.
"Let me see what I can do... sir"
07-15-2021, 11:31 PM | #2 |
Rep 357
Drives: E70 X5M
Where is the clunk coming from? Front, rear, underneath where transmission/transfer case would be?
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
07-16-2021, 05:33 PM | #3 |
Rep 852
The clunk is coming from underneath, seems like where transmition/tr case is.
10-13-2021, 12:32 PM | #5 |
Rep 852
No, have not addressed it. Still there. not completely sure what it is. Trying to find another e70 to compare.
10-13-2021, 07:51 PM | #6 |
Rep 107
I have the same thing happen. A soft think and a jerk after placing it in reverse, before moving. I have the v8. E70 2007 89k miles. Had the dealer look at it, and they said they could not find anything wrong.
I know a few folks recommend doing a transmission fluid flush/change or maybe transfer case fluid change as the car ages. The local dealer is not recommending it though. |
11-03-2021, 09:00 PM | #8 |
Rep 26
Internals on transmissions usually do not clunk and if they do, it is loud and forceful.
I am going to bet you have 1 of 3 things: Struts and strut mounts are worn Engine and or transmission mounts are worn A-arm bushings, ball joints, or tie rod ends are worn. One other possibility is the bolts connecting the undercarriage to frame are a slight bit loose, but this is unlikely and usually only a result of having those previously removed. |
