04-09-2022, 05:23 PM | #1 |
Rep 325
OEM Genuine BMW 20" Style 300M Wheels Rims - E70 X5M/E71 X6M - Cincinnati, OH
Up for sale is a set of OEM, Genuine BMW Style 300M wheels. These were original equipment on E70-generation X5M and E71-generation X6M vehicles. These were only offered for a limited number of years and are a rare option. List price from BMW for a new set of these wheels is $4280. Fitment: **Attention - these wheels have a 74.1 mm center bore in front, and 72.56 mm center bore in the rear.*** They are direct fitment (no spacer or adapters needed) on the following vehicles 2009-14 BMW X5M (E70 chassis) 2009-14 BMW X6M (E71 chassis) 2008-14 BMW X6 (E71 chassis) They will fit on the following vehicles using a 74.1 mm to 72.56 mm hub adapter set with extended lug bolts (~$125 from ECS Tuning). 2007-13 BMW X5 (E70 chassis) 2014-18 BMW X5 (F15 chassis) 2015-19 BMW X6 (F16 chassis) Wheel Specs: Front: 20x10 ET40; BMW Part no. 3611679605 Rear: 20x11 ET35; Mercedes Part no. 36116790606 74.1 mm center bore in the front, 72.56 mm center bore in the rear 5x120 bolt pattern Wheels are in very good used condition. They are structurally sound and free of bends or cracks. Each wheel was spun on a wheel balancer and found to be straight and true. Cosmetically wheels are an 8/10. They exhibit some flaws from age and normal use. There are 4 areas where curb rash has been repaired by filing and polishing the affected areas. These repaired areas are difficult to see but are visible upon close inspection. Some scuffs, nicks and scratches from normal use. Some oxidation in the clear coat near the centers. Clear coat also shows some fading and flaking in some areas. Overall these wheels are clean enough to run as-is, or can be refinished if desired. BMW center caps included. No valve stems or TPMS included. Asking $OLD picked up in Cincinnati, OH. Will ship within the continental USA at buyer's expense. Front Wheel #1 Front Wheel #2 Rear Wheel #1 Rear Wheel #2
2006 BMW E46 M3 Coupe - 6MT - Titanium/Imola
1999 BMW E36 M3 Coupe - 5MT - Estoril/Dove 2000 Honda Civic Si 2011 Toyota Tacoma PreRunner T/X TRD Last edited by Titaniu//M; 10-24-2022 at 09:51 PM.. |
04-09-2022, 07:52 PM | #2 |
Rep 521
Don't be afraid of these if you have a standard X5. I ran them for 5 years (winters only) with hub-adapter spacers & bolts. Great rim, great shape. GLWS.
04-09-2022, 08:03 PM | #3 |
Rep 325
Thank you, much appreciated!
1999 BMW E36 M3 Coupe - 5MT - Estoril/Dove 2000 Honda Civic Si 2011 Toyota Tacoma PreRunner T/X TRD |
04-24-2022, 05:06 PM | #4 |
Rep 325
Bump - price dropped to $1800
05-04-2022, 04:50 AM | #5 |
Rep 325
Bump
06-19-2022, 02:08 PM | #6 |
Rep 325
Bump - price reduced
