01-02-2022, 11:03 AM | #1 |
Rep 405
Intermittent Coolant Leak
2012 35i xDrive, 70K Miles - vehicle seemed to develop an intermittent coolant leak, which I believe is exiting through the Expansion Cap, through the little hole on the top of the tank through the cap.
Saw a few drops a a little over a week ago and added some coolant to the tank, which was a bit low. After that, didn't see any leaks for about a week, until yesterday, when I went into the garage, saw s little puddle on the floor. Leak isn't consistent, so I eliminated the Expansion Tank itself, which I actually replaced a few months back. Water Pump and Thermostat were replaced twice since 2018. Anyone experienced this intermittent leak? Any ideas on what it could be? |
01-03-2022, 11:53 AM | #2 |
Rep 4,322
How did you rule out the expansion tank?
My tank was cracked on the bottom and I couldn’t see the leak, I replaced it and the new one cracked too. I had to replace it again and now it’s fine. |
01-04-2022, 12:34 PM | #3 | |
Rep 405
My assumption is that if there was a crack on the tank itself, then it would continue leaking, but that's not the case. I've seen some information that mention a possible Water Pump issue and if the pump goes out every so often, that could explain the pressure buildup and causing the coolant to bubble over through tank cap. |
01-05-2022, 04:11 AM | #5 |
Rep 405
01-12-2022, 02:25 PM | #6 |
Rep 405
Update, in the event anyone is tracking down a mysterious leak.
In my case, it didn't turn out to be the expansion tank, it was/is actually the Heater Control Valve that developed a small crack and would leak intermittently, primarily when the heat is on. I took off the undercarriage panel and I saw some coolant residue on the hose coming off the valve and down towards the subframe, as I looked further up, I saw a bit of coolant dripping from the valve, thus identifying my leak. I also ran a diagnostic check and received an error code for the Driver Side Water Valve (Heater Control Valve), I assume the leak and code have some correlation to each other. New valve on order and should be a quick 20 minute fix. So, all this to say, this is another item to check if chasing down any phantom leaks. |
