07-30-2019, 10:13 AM | #1 |
Rep 47
X5M Fuel Filter DIY?
gang;
- can't locate info on it - when should it be swapped out? - anyone done it and wants to post impressions? 2013 with 50K miles |
07-30-2019, 05:26 PM | #2 | |
Rep 728
https://www.realoem.com/bmw/enUS/sho...diagId=16_0659
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
08-08-2019, 01:46 AM | #3 |
Rep 3,151
https://www.realoem.com/bmw/enUS/sho...diagId=16_0747
You can replace number 2 as a maintenance item.....I will be doing this as soon as i can be bothered to order it.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
08-08-2019, 06:48 AM | #4 | |
Rep 119
08-08-2019, 08:00 AM | #5 |
Rep 99
x5M - the pump and filter are on same unit. Great advice above about how to change. Make sure you go to the right side (passenger) and the gas is low (the other side is the level sender).
https://www.realoem.com/bmw/enUS/sho...diagId=16_0659 https://www.ecstuning.com/Search/Sit...h/16117212585/ |
08-08-2019, 09:49 AM | #6 | ||
Rep 3,151
Current Mods:
08-08-2019, 10:37 AM | #7 |
Rep 119
08-08-2019, 10:46 AM | #8 | |
Rep 3,151
https://rover.ebay.com/rover/0/0/0?m...2F183739792676 Also, my car is euro spec so maybe there is a difference between euro and US spec.
Current Mods:
08-08-2019, 03:43 PM | #9 |
Rep 47
Thanks everyone;
So the consensus appears to be that in order to change out a fuel filter, one needs to spend $350+ as it's integrated within the pump. Do I have this correct? Having had '3' fuel pumps fail on my E39 M5 over 300,000 miles (filter was not integrated), its a very good idea to change out a pump as preventative maintenance, short of 75,000 +/-. |
08-08-2019, 04:54 PM | #10 |
Rep 357
Modern cars these days don’t have a REAL fuel filter that traps fine particles. The ones in the gas tank just filter or I would say trap larger objects that could be floating in the tank like rust scales, metallic contaminants ,and trashes that can enters the fuel tank during gas fill ups(sharing pump nozzles). Gas station usually have filters at the pump before it goes into the car.
Those in-tank filters usually last the lifetime of the pump. I wouldn’t worry about it. |
08-08-2019, 06:45 PM | #11 |
Rep 369
I am due to change the pump in my X5M as I always change out fuels pumps at 100k miles, well almost. The only time my 4.8is left me stranded was.....in the middle rush hour on the 91 freeway, fast track, then each of the 4 lanes over. 30 minutes to get it to the side. Needed a fuel pump which I already had on the shelf. 105k miles.
08-09-2019, 06:42 AM | #12 | |
Rep 119
08-09-2019, 06:46 AM | #13 | ||
Rep 3,151
Current Mods:
08-03-2020, 06:18 PM | #14 |
I wanna go fast
198
Rep 392
Did you ever find out if there is a 2nd fuel filter that you can replace without the pump? That looks like the diesel model to me.
My 13 x5 m is currently in limp mode. 64k miles with a p0087 code. I hope it is the low pressure fuel sensor and not the pump. Seems like 64k miles is low for a fuel pump to go bad. Does running fuel system cleaner help clean the fuel filter? Any advice is appreciated. |
08-03-2020, 06:28 PM | #15 | |
Rep 3,151
Current Mods:
08-04-2020, 02:18 PM | #16 | |
Rep 12
I work at Toyota R&D; it's mind boggling to try to wrap your head around each destination's regulatory constraints. Folks would be surprised at all of the nuanced changes a new delivery destination imposes on vehicle development. |
08-04-2020, 02:20 PM | #17 | ||
Rep 3,151
Current Mods:
08-04-2020, 07:41 PM | #18 | |
Rep 357
Drives: E70 X5M
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
01-18-2022, 10:40 AM | #19 |
Rep 219
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
The B12 Chemtool breaks off large portions of fuel solids, bringing up the dreaded Reduced Power engine error. A safer alternative is use a Nitrogen-based PEA fuel additive instead: Techron, Gumout Regane, Lucas Fuel Treatment(BEST). It’s this magic sauce that melts fuel solids away. Best applied to quarter tank and run hard until nearly empty. Fill only with Shell, Chevron, or Sinclair/ConocoPhillips Premium gasoline.
