      10-23-2020, 09:37 PM   #1
bleha
Drives: 2021 X3 M 40i , 2014 Q5 TDI
A6D1-Auxiliary water pump fault
Hi guys,i have a 2011 x5 5.0 and put my Carista app device run through vehicle
and it discovered a fault with auxiliary water pump.
I have no cel or warning lights so wandering is that something i should worry about.I tried to reset the fault but it came right back.
Thanks.
      10-24-2020, 01:58 PM   #2
Ryan5034
Drives: 2019 X5 50i
I had this before as well. You'll have to replace the pump. I would not bother doing it the pump works fine and the error is cosmetic. Mine got replaced because of a recall on the pump then the error went away.
      10-24-2020, 07:50 PM   #3
bleha
So there is a recall?
      07-12-2021, 10:07 AM   #4
mightyb28
Drives: BMW Z4
Here are the recalls:
https://www.cars.com/research/bmw-x5_m-2010/recalls/
Engine and engine cooling
Recall date
2018-04-18
Recall no.
18V248000
BMW of North America, LLC (BMW) is recalling certain 2011-2012 BMW 550i, 550i xDrive, 550i Gran Turismo, 550i Gran Turismo xDrive, 750i, 750Li, 750i xDrive, 750Li xDrive, 760Li, X5 xDrive50i, X5 M, X6 xDrive50i, X6 M, ActiveHybrid7, MINI Cooper S Convertible, John Cooper Works (JCW) Convertible, Cooper S Countryman, Cooper S Countryman ALL4, Cooper S, JCW, Cooper S Clubman, JCW Clubman, Cooper S Roadster, JCW Roadster, Cooper S Coupe, JCW Coupe and Rolls-Royce Ghost, 2011 BMW X6 Hybrid and 2012 BMW 650i Coupe, 650i xDrive Coupe, 650i Convertible and 650i xDrive Convertible vehicles. The electric auxiliary water pump may fail and cause the circuit board to overheat.
Hide details
Recall consequence
If the circuit board were to overheat, it can increase the risk of a fire.
Recall action
BMW will notify owners, and dealers will replace the electric auxiliary water pump, free of charge. Depending on the model, there are currently limited parts available, however not all parts are available at this time. Owners will be notified of the recall beginning June 11, 2018, and will receive a second notification when remedy parts become available. Owners may contact BMW customer service at BMW 1-800-525-7417, MINI at 1-866-825-1525, or Rolls-Royce at 1-877-877-3735. Note: BMW recommends that owners park their vehicle outdoors until the recall remedy has been performed.
      07-12-2021, 10:08 AM   #5
mightyb28
Drives: BMW Z4
I have that same Fault Code:
*JBE junction box electronics
A6D1 auxiliary-water pump
Part # 9292708
Hardware # 02
Variant: 5745
Does anyone have an engine bay picture of where the Aux Water Pump is located?
      07-15-2021, 04:08 AM   #6
handcn
Drives: 2011 X5 M
Part # 9292708
Hardware # 02
Variant: 5745
FYI
      07-16-2021, 09:53 AM   #7
mightyb28
Drives: BMW Z4
Thank you handcn, but I can't tell from that picture where the aux water pump is located on the cooling system.
Do I access it from above, or below the engine bay?
Is the a step-by-step showing a zoomed out picture and then guides on where I go?
I have the "BMW-X5-E70-Service-Repair-Workshop-Manual" but I can't locate it in there either.
      07-16-2021, 10:02 AM   #8
mightyb28
Drives: BMW Z4
Exclamation BMW-X5-E70-Service-Repair-Workshop-Manual
https://drive.google.com/drive/folde...ff?usp=sharing
werdn656.00
      07-16-2021, 03:45 PM   #9
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Pump is pretty easy to replace, pic above is for a s63, which has different bracket. Watch video below, will help you to replace. This is the perfect time to replace crappy plastic T connections in turbo coolant lines with metal T's.
      07-16-2021, 04:04 PM   #10
Also just a FYI, the 50i and M also have an auxiliary pump for the aux radiator. This pump is located on the passenger side of the radiator base, you have to pull the fan to get to it. The code you listed is pretty generic so it could be either pump. If your turbo pump has never been replaced, then best do it anyway. Dealer should do it for free under recall
      07-19-2021, 10:12 AM   #11
mightyb28
Drives: BMW Z4
And that's the difficulty. Which pump. But I guess you just start replacing them with new and eventually the fault code will go away.
