10-04-2019, 02:26 PM | #1 |
Rep 18
X5 e70 not cranking
Hey all. I’ve search high and low for possible causes to my issue but only found similar issues with no solutions.
This morning I took my 2012 x5 35d out to the store with no issues. When getting back in my car 20 mins later it just wouldn’t turn over. I haven’t done much troubleshooting other than checking oil level and trying a different key. Both inserted. As my car is stuck in a parking lot and my mechanic is closed till Monday, I am wondering what I can try before towing it Sunday night to my mechanic. When I push the start button nothing happens. No click, no flicker. There are no check control on engine codes. Almost like the button is disconnected somehow? I’m heading there in a few hours with booster cables to charge up the battery. Just wondering what else I should try? Thanks for your help! |
10-04-2019, 02:40 PM | #2 |
Rep 1,564
Check the Engine ground straps, pretty common they become corroded and just break off.
NorthCountryGuy1713.00 |
10-04-2019, 03:23 PM | #3 |
Rep 357
If you have a jump cable, just clip a wire from the engine(hook) to any body frame bolt. Just so you can start it and get the car home and figure out the ground strap.
10-05-2019, 12:50 AM | #4 |
The Quiet One
1713
Rep 624
I had started a thread about accessing the X5 ground cable.
Search is your friend. I think I titled it something like 2013 X5 35i ground strap location... Add : https://www.xbimmers.com/forums/show....php?t=1632755
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse 2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s 2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s |
10-05-2019, 06:31 AM | #5 |
Rep 18
Update:
I went and had a look at it last night. first thing I hooked up the booster cables from my car and let it idle for 20 mins to charge up. In the mean time I searched for the ground straps but couldn't see anything from the top of the engine. I hooked up a separate set of cables as instructed from the engine hook to the main frame anyway just to try it. Still nothing happens when I press the start switch. So I dont think its the battery or the grounding. I did however manage to pull a few codes using carly. I had all 6 glow plug codes: 004A4E,004A3E, 004A2A, 004A14, 004A6E, 004A54 Also have Alternator code: 004A07. I highly doubt I have 6 failed glow plugs and a bad alternator. So I will be towing to my mechanic for Monday morning. I will report back with findings. |
10-05-2019, 06:54 AM | #6 |
The Quiet One
1713
Rep 624
Best Wishes
10-05-2019, 09:34 AM | #7 |
Rep 1,564
I don't know much about diesels but from what I remember driving an old peugot 504 back in the day, you had to let the glow plugs warm up for a bit before starting. I am sure today it's all automated today and the engine will not crank until the glow plugs are a certain temp. All this circles back to either a bad glow plug controller or ground/battery issue....check out this thread, exact same issue as yours, turned out to be a ground issue. On the second page their are pics on the proper ground points.
https://xoutpost.com/bmw-sav-forums/...eat-issue.html |
10-05-2019, 10:42 AM | #8 | |
Rep 18
What if I took a jumper from the engine hook and connected it to the battery negative post? Seems like it could work. But with bmw the car would probably explode. |
10-05-2019, 12:44 PM | #9 |
Rep 357
Try jumping from another car. Running car battery connect pos+ and neg - straight battery terminals.
Non working car , positive to the engine bay pos terminal and “ Neg to engine hook”. This is how I got mine to start, due to bad grounds. |
10-05-2019, 01:53 PM | #10 |
Rep 18
I will try that tonight. Thanks!
10-05-2019, 05:11 PM | #11 | |
Rep 18
Thanks to all who helped out. |
10-05-2019, 05:43 PM | #12 |
Rep 357
Glad it worked. I had replaced my factory ground strap along with adding a few more around the engine just in case. The factory strap is at the location where any kind of moisture from the road will get on it. Thanks to the wonderful geniuses at bmw.
10-05-2019, 08:34 PM | #13 |
The Quiet One
1713
Rep 624
On electrically complicated cars, ground point status is a very important issue. I maintained a 32 year old Porsche 928 S4 for 15 years very well. All the inherited gremlins were due to ground issues, and some were very hard to diagnose. There were 12 masse punkt that all grounds wires from components attached to. If one were faulted it jeopardized all grounds that were attached to that particular masse punkt/ground point.
I had a recent problem with my 650 due to two ground wires/points being faulted. Caused a myriad of symptoms that even outdid my ability to repair. Was even difficult for a seasoned BMW indy to conquer. A loose bolt to a grounding harness in the bridge of the engine coils and a broken small brown ground wire in the circuit to the BUS from the crankshaft sensor was causing the DME to go ‘bananas’. Codes for transmission overheating when car cold, chassis stabilization codes, invalid crankshaft rotation codes all simultaneously caused car to go into immediate Safe Mode. This was intermittently, and left car undrivable. In my X5 once I was able to locate and see my engine ground strap was green, I changed it immediately. Had no symptoms, and didn’t want any. The engine ground straps in the N55 and N63 are basically in the same place low down on driver’s side just above the half axle. Prone to road moisture riding in from the front. I definitely consider this ground as something requiring preventative maintenance. This means change it out periodically depending on your mileage, geographic location (road salt v. none), etc... On the X5 it is a PITA to replace.
10-06-2019, 12:34 AM | #14 | |
Rep 1,564
10-06-2019, 08:55 AM | #15 |
Rep 357
Mr. Rednex. I hope you’re taking pic as you’re tackling your one hell of a project. You must love your e70 to pour all that $$ and time.
I would have put it on an F85 for sure |
10-06-2019, 02:43 PM | #16 | |
Rep 1,564
I really tried to like the F85 but just cant..I am to in love with the E70, still the best looking X5 (especially with the Aero kit)IMHO. I was originally just going to do the valve guide seals and rented the entire AGA tool set to do it but when I borescoped it and saw the amount of carbon build up, I knew I had to clean it up before I start messing with the boost levels so I decide to pull the heads so I could properly clean the valves, pistons and combustion chambers. Was tempted to just replace the entire engine while they are discounted but the bearing surfaces and cylinder walls look excellent for 150K so going to make this my test engine for how far I can push it. I am snapping pics (some below) along the way and will create a separate thread for anyone interested. |
