09-15-2021, 04:48 AM | #1 |
Rep 1
new to me X5M crank no start and other problems.
hi guys. just bought an x5m from an auction and working on it now for a few days. i have several issues. two major ones and a few smaller ones. attached is an ista fault list. car was and is still put in neutral manually at the transmission.
1. crank no start. i bought the load shedding relay but it's not at the DME or at least I didnt found it. it's light green but there is only a blue one right next to it. and why does the CAS complain? it is cranking. 2. the rear bags are empty. tried to fill the bags with ista but I can't even hear a compressor. so is it most likely the compressor or the module? 3. cic - seems the previous owner fried the amp and combox. have them out of the car and I may send them in for repair. and yes it seems like there was at some point water in the trunk area. checked all fuses already and all module connections in the rear and at the junction box. and a new CA module is on its way. |
07-30-2022, 11:31 AM | #2 |
Rep 7
Hi Zekarus! Did you ever find the issue that you were having? I have a similar issue with my E70 50I.... fault codes on Injector circuits and no comm issues, and it is cranking with no start.
